How to send a .trc ?
fokker2003
Post by fokker2003 » Sun 19. Apr 2015, 11:07
Good morning.
How can I transmit a .trc file read with PCAN USB?
I explain. I want to read a full CAN frame via OBD connector in a car and transmit it to different car components in bench, as instrument cluster, ABS unit, etc.... for testing.
Is this posible with PCAN explorer 5 and PCAN USB?
Thank you very much for your help.
Re: How to send a .trc ?
Post by K.Wagner » Mon 20. Apr 2015, 08:16
if you want to read CAN frames from the bus, store them, and play then back in the same order and with the same separation time between messages, then you need the PCAN-Trace application. PCAN-Explorer doesn't support this feature.
