How to control the availability of the output ?
MandyD
Post by MandyD » Tue 12. May 2015, 12:05
Hello everyone, hello peak's community,
I need your precious help today. Indeed I got a device where I need to control the availability of the output of my PCAN-Micromod Analog 1.
This is a device where I can't put all my outputs enabled at the same time. I know how to control them by using PCAN View. I just have to create message with the output id as you can see on the picture. But I have to do it manually.
is it possible to control the output by loading a program in the PCAN Micromod analog 1 with the software PCAN Micromod configuration?
Thank you for your help.
Mandy
Re: How to control the availability of the output ?
Post by M.Maidhof » Tue 12. May 2015, 15:54
no, this will not be possible. This has to be done by an external CAN device. The MicroMod Analog1 could only be configured to react on incoming CAN messages (with the standard firmware). To perform such a behaviour, a special firmware must be created for the PCAN-MicroMod.
MandyD
Post by MandyD » Tue 12. May 2015, 16:57
That's what I thought. Thank you for your quick answer.
Best regards.
Mandy.
