How to Create CAN network with PCAN USB
USB to CAN Interface
tydix
Post by tydix » Mon 27. Jul 2015, 11:52
Hi.
Im, new to CAN network. I have purchased PCAN USB as leraning tool.
If i want to create small CAN nertowork is it enough to add 120 Ohms resistor between CANH and CANL cables.
Plese see attached picture 1.
2015-07-27 12_39_29-Untitled - Paint.png (10.02 KiB) Viewed 8970 times
If I will transmit CAN messages will they be transmited on this network ? I do not have one more PCAN USB tool to check it. I have other hardware which should be able to receive CAN messages which I'm transmiting, but it is not getting anything so maybe i misunderstood something.
Picture 2 shows how hardware is connected to CAN network. I do not mix CANH and CAN L cables.
2015-07-27 12_45_56-Untitled - Paint.png (11.26 KiB) Viewed 8970 times
Most important for me to know is if it is enough to add 120 Ohm resistor to create CAN network or I need soemthing more
Re: How to Create CAN network with PCAN USB
Post by M.Maidhof » Mon 27. Jul 2015, 13:55
a CAN network must have two 120 Ohm resistors between CAN-L and CAN-H (on both ends of your CAN cables).
Please check the baudrate of your connected device, you must use the same baudrate for all connected CAN nodes
