Plotter Signal vs Signal
Frederick
Post by Frederick » Tue 6. Oct 2015, 16:45
Hi there,
in the plotter, I would need to have instead instead of the time stamp on the x-axis another signal. i.e. Massflow against pressure or temperature vs. pressure. is it possible? there is a special tool which has this feature?
Thanks in advance.
the answer can also be German!
MfG
Frederick
Re: Plotter Signal vs Signal
Post by M.Maidhof » Wed 7. Oct 2015, 10:27
the Plotter tool will only offer the time in X axis, a X-Y signal display is not available. But you can export a trace file into csv, and use Excel or a similar tool to create X-Y diagramms.
