Merge Trace files
Merge Trace files
Post by PEAK-Support » Fri 19. Aug 2011, 13:12
To merge single Trace files into one huge, you could use our free TraceMerge Tool.
If you use, for example, the Loosless Trace Script inside the PE5/6 and like to get all files back in one large Trace File.
Also usable for converted BTR files from the Router Pro Hardware.
usage: TraceMerge.exe Trace_1.trc Trace_2.trc etc.
result: Trace_1_Merge.trc which is now a combination of the first and second (etc.) trace file.
Limitations:
- need minimum TraceFile Format 1.3 (PE5)
- maximum Lines for target file 99.999.999 (99Mio)
- target file size limited to ~4Gbyte
- NO CAN FD support at the moment - only CAN2.0a/b (File Format 1.3)
*UPDATE* of File on the 15th of October 2021 (sort Option)
*UPDATE* of File on the 8th of July 2024 (add 64 Bit Version)
If you work with a 64Bit OS - please use the 64Bit Version. It is much faster as the 32 Bit Version, and could save you a lot of time:
Trace_Merger.zip
(3.89 MiB) Downloaded 2719 times
