Button Propertires Go Back to Default
When I open and close the project or move between design mode and run mode some of the button properties I change for the rocker switches go back to their default value (on and off value, caption) but some (on and off color) keep changes I've made. These buttons are tied to a message I try to send out but won't update because the buttons keep going back to 0 for both on and off. Any idea what might be going on? Thanks.
Re: Button Propertires Go Back to Default
Which version of PCAN-Explorer and Panel Add-in are you using?
5.1.4.680 for Explorer, not sure how to find Panel Add-In version.
I think the same issue has another symptom of the message that is supposed to be sent when the toggle buttons are used never is. The same project is working on a different computer, but won't work on mine.
The Add-in version is displayed in the Add-in Manager dialog box, which you can access via the Tools menu -> Add-in Manager command. The version of your Panel Add-in should be 3.0.9.350.
I went back to 5.1.3 and the problem went away. I guess I'll just use that version. Thanks for the help.
It have nothing to do with the Version - simply use the AddIn Manager to activate - deactivate AddIns and restart the PE4/5 again.msukup wrote:I went back to 5.1.3 and the problem went away. I guess I'll just use that version. Thanks for the help.
Problem solved -Thread closed
