PeakCAN linux driver version 7.15.2
gmlim
Post by gmlim » Mon 22. Feb 2016, 01:45
Hi
I have previously used PeakCAN linux driver version 7.4 on Redhat and now I would like to upgrade to version 7.15.2, but after installing and trying cat /proc/pcan with the PCAN-USB Pro FD device plug into my computer it showed the error message: No such file or directory
I have tried:
sudo make uninstall
sudo rmmod pcan
make clean
make NET=NO_NETDEV_SUPPORT
sudo make install
cat proc/pcan
Below are some pictures showing the build messages
1) make uninstall.png (78.06 KiB) Viewed 13676 times
2) rmmod pcan.png (83.51 KiB) Viewed 13676 times
3.1) make clean make NET=NO_NETDEV_SUPPORT.png (212.42 KiB) Viewed 13676 times
3.2) make clean make NET=NO_NETDEV_SUPPORT.png (220.39 KiB) Viewed 13676 times
4) sudo make install.png (208.73 KiB) Viewed 13676 times
5) cat proc pcan.png (39.14 KiB) Viewed 13676 times
S.Grosjean
Re: PeakCAN linux driver version 7.15.2
Post by S.Grosjean » Mon 22. Feb 2016, 14:51
Nothing is displayed by "cat /proc/pcan" because, according to your logs, pcan v7.15.2 failed to build.
On our side, we have successfully built v7.15.2 against 2.6.32.70 LTE version of the Kernel.
So, there is something wrong in the headers of your Kernel that prevents pcan to be built.
Could you first retry to build 7.4, please? We would be sure that you are able to build it with your current config...
Stéphane
— Stéphane
gmlim
Post by gmlim » Tue 1. Mar 2016, 02:45
Hi
I have tried to build 7.4 but it is also unsuccessful
1) make_clean1.png (95.82 KiB) Viewed 13655 times
2.1) make_NET=NO1.png (215.66 KiB) Viewed 13655 times
2.2) make_NET=NO2.png (219.47 KiB) Viewed 13655 times
3) make_install1.png (200.43 KiB) Viewed 13655 times
4) cat_procpcan1.png (195.7 KiB) Viewed 13655 times
gmlim
S.Grosjean
Post by S.Grosjean » Tue 1. Mar 2016, 11:11
The fact that 7.4 does not compile only shows that you've got a problem in your (kernel) headers. And this problem is the same that prevents from 7.15.2 to be built.
As a workaround, I may suggest to do a symlink to your current gcc includes, something like that:
$ cd /lib/modules/$(uname -r)/build/include
$ sudo ln -s $(gcc -print-file-name=include)/stdarg.h
Then, back into peak driver dir, rebuild the driver:
$ cd /usr/local/swdev/peak-linux-driver-7.x
$ make NET=NO
PS: please try to copy-paste your logs from the screen in text format, rather than enclosing screen-shots pictures, thx!
Stéphane
— Stéphane
gmlim
Post by gmlim » Wed 2. Mar 2016, 00:56
Hi Stéphane
Thank you for the workaround I am now able to build 7.15.2 successfully!
In future I will copy and paste in text form instead of pic.
Just curious if I my original version is 7.4 and when I want to upgrade to 7.15.2, what are the proper steps to be done to prevent the problem of (kernel) headers from appearing?
(for 7.4 there is no option to make uninstall)
gmlim
S.Grosjean
Post by S.Grosjean » Wed 2. Mar 2016, 09:36
Ok, nice to hear that.
You shouldn't encounter such a problem in the future: there is no obvious reason why your <stdarg.h> is not found when compiling the Kernel. Maybe it's a mix between your (very) old Kernel version and a more recent version of gcc...
You're right: the "uninstall" target has been added later in the "pcan" history. With more recent versions, the right way to install a new version of "pcan" as if it was from scratch is:
$ sudo make -C peak-linux-driver-x.y.z uninstall
$ rm -rf peak-linux-driver-x.y.z
Then continue with installing the new package...
Note: FYI, we just delivered a fresh new beta version of pcan which includes lots of new features to play with...
Stéphane
— Stéphane
gmlim
Post by gmlim » Tue 8. Mar 2016, 04:03
Hi
I would also be installing PeakCAN linux driver version 7.15.2 on Ubuntu 10.04 but encounter problem when I execute make NET=NO
This time round the error doesn't seems to be due to missing stdarg.h file thus the workaround to do a symlink to current gcc includes does not work;
Below is the build message:
lohyh@lohyh:/usr/local/SW_DEV/peakcan/peak-linux-driver-7.15.2$ make NET=NO
make[1]: Entering directory `/usr/local/SW_DEV/peakcan/peak-linux-driver-7.15.2/driver'
make[1]: *** No rule to make target `depend'.  Stop.
make[1]: Leaving directory `/usr/local/SW_DEV/peakcan/peak-linux-driver-7.15.2/driver'
*** Host machine kernel version=2.6.32-33-generic
*** Driver kernel version=2.6.32-33-generic
*** Path to kernel sources=/lib/modules/2.6.32-33-generic/build
*** use KBUILD=yes
*** cc version=4.4.3
make -C /lib/modules/2.6.32-33-generic/build SUBDIRS=/usr/local/SW_DEV/peakcan/peak-linux-driver-7.15.2/driver        EXTRA_CFLAGS="-I/usr/local/SW_DEV/peakcan/peak-linux-driver-7.15.2/driver        -DNO_DEBUG -DMODVERSIONS -DPARPORT_SUBSYSTEM -DUSB_SUPPORT -DPCI_SUPPORT -DPCIEC_SUPPORT -DISA_SUPPORT -DDONGLE_SUPPORT -DPCCARD_SUPPORT -DNO -DNO_RT " V=0 modules
make[2]: Entering directory `/lib/modules/2.6.32-33-generic/build'
make[2]: *** No rule to make target `modules'.  Stop.
make[2]: Leaving directory `/lib/modules/2.6.32-33-generic/build'
make[1]: *** [all] Error 2
make[1]: Entering directory `/usr/local/SW_DEV/peakcan/peak-linux-driver-7.15.2/lib'
cc src/libpcan.c -DNO_RT -I. -I../driver -fPIC -shared -O2 -Wall  -Wl,-soname,libpcan.so.0 -lc  -o libpcan.so.0.6
make[1]: Leaving directory `/usr/local/SW_DEV/peakcan/peak-linux-driver-7.15.2/lib'
make[1]: Entering directory `/usr/local/SW_DEV/peakcan/peak-linux-driver-7.15.2/test'
cc -DNO_RT -g -I. -I../lib -I../driver  src/receivetest.c src/common.c  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest
cc -DNO_RT -g -I. -I../lib -I../driver  src/transmitest.cpp src/common.c src/parser.cpp  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -lstdc++ -o transmitest
cc -DNO_RT -g -I. -I../lib -I../driver  src/bitratetest.c src/common.c  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o bitratetest
cc -DNO_RT -g -I. -I../lib -I../driver  src/filtertest.cpp src/common.c  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -lstdc++ -o filtertest
cc -DNO_RT -g -I. -I../lib -I../driver  src/pcan-settings.c  -lpcan -L../lib -L/lib -L/usr/lib -L/usr/local/lib -lpopt -g -o pcan-settings
make[1]: Leaving directory `/usr/local/SW_DEV/peakcan/peak-linux-driver-7.15.2/test'
Reason: Added [code] tag for better readability.
S.Grosjean
Post by S.Grosjean » Tue 8. Mar 2016, 09:47
The goal of the given workaround was to fix the issue with your other configuration. This workaround does normally not need to be installed each time! (except if the issue was actually the same).
First of all, be sure to have installed the right linux headers package:
sudo apt-get install linux-headers
Moreover, please, give me the result of:
$ ls -l /lib/modules/`uname -r`
and
$ ls -l /lib/modules/`uname -r`/build/
Thx,
Stéphane
— Stéphane
gmlim
Post by gmlim » Wed 9. Mar 2016, 02:06
Hi
Below are the results
lohyh@lohyh:~$ ls -l /lib/modules/2.6.32-33-generic/
total 3836
drwxr-xr-x  3 root root   4096 2015-03-31 10:03 build
drwxr-xr-x  2 root root   4096 2011-07-19 20:09 initrd
drwxr-xr-x 10 root root   4096 2014-07-15 09:36 kernel
drwxr-xr-x  2 root root   4096 2016-02-19 12:26 misc
-rw-r--r--  1 root root 616454 2016-03-08 08:52 modules.alias
-rw-r--r--  1 root root 594096 2016-03-08 08:52 modules.alias.bin
-rw-r--r--  1 root root   5084 2011-07-08 10:39 modules.builtin
-rw-r--r--  1 root root   6363 2016-03-08 08:52 modules.builtin.bin
-rw-r--r--  1 root root     69 2016-03-08 08:52 modules.ccwmap
-rw-r--r--  1 root root 270678 2016-03-08 08:52 modules.dep
-rw-r--r--  1 root root 399005 2016-03-08 08:52 modules.dep.bin
-rw-r--r--  1 root root   1405 2016-03-08 08:52 modules.ieee1394map
-rw-r--r--  1 root root    218 2016-03-08 08:52 modules.inputmap
-rw-r--r--  1 root root  24886 2016-03-08 08:52 modules.isapnpmap
-rw-r--r--  1 root root     74 2016-03-08 08:52 modules.ofmap
-rw-r--r--  1 root root 104668 2011-07-08 10:39 modules.order
-rw-r--r--  1 root root 407961 2016-03-08 08:52 modules.pcimap
-rw-r--r--  1 root root   1597 2016-03-08 08:52 modules.seriomap
-rw-r--r--  1 root root 222671 2016-03-08 08:52 modules.symbols
-rw-r--r--  1 root root 288617 2016-03-08 08:52 modules.symbols.bin
-rw-r--r--  1 root root 918040 2016-03-08 08:52 modules.usbmap
lohyh@lohyh:~$ ls -l /lib/modules/2.6.32-33-generic/build/
total 4
drwxr-xr-x 2 root root 4096 2016-03-02 08:28 include
S.Grosjean
Post by S.Grosjean » Mon 14. Mar 2016, 10:52
total 4
If what you have pasted above is really the content of the "build" directory of your Ubuntu 10.04 system, then your "Kernel" tree is missing of almost everything to be able to build any out-of-tree Linux driver! For example, it should contain (at least) the Makefile!
On the host running Ubuntu 10.04, can you please give me the result of:
$ dpkg --get-selections "linux*"
Stéphane
— Stéphane
