Change settings through terminal
tox104
Post by tox104 » Tue 5. Apr 2016, 13:18
Hello i cant figure out how to change settings through terminal.
? responds with possible commands:
rg
sg
sp
g
p
sg -returns default config
Previous posts mentioned mg command.
Maybe you could provide example string or commands to change configuration.
Terminal output
Terminal output
S.Michaelsen
Hardware Development
Re: Change settings through terminal
Post by S.Michaelsen » Tue 5. Apr 2016, 13:44
To cahnge e.g. the Pin:
PCAN>mg1,2222
PCAN>rg
Writing EEPROM - OK
PCAN>sg
GPRS configuration data:
updated: 2014.12.09-10:24:48
IMEI:
Pin: 2222
Note that setting blank values might not work.
tox104
Post by tox104 » Tue 5. Apr 2016, 14:32
Thanks for the fast reply
M.Gerber
Design & Documentation
Note by Moderator
Post by M.Gerber » Tue 5. Apr 2016, 14:44
Hello Tox,
Please create a new topic the next time you have a question. I've separated this question.
Thanks!
Mark
