Load PXCP.dll in C++ Builder
Ramiro Cavazos
Post by Ramiro Cavazos » Tue 24. May 2016, 12:38
In the PCAN-XCP API are provided the PXCP.dll files.
I am using the C++ Builder and for some reason I can not load the library. I assume that the library was created in Microsoft Visual C++.
Is it possible to get the dll files in order to use them with C++ Builder?
Best regards
Re: Load PXCP.dll in C++ Builder
Post by K.Wagner » Tue 24. May 2016, 15:37
we have to check the DLL on this regard. It could be that indeed it has some incompatibility regarding C++ Builder (byte alignment for example). Meanwhile you can try to use the library with static load by using the PXCP.lib attached to this post.
PXCP.zip
Library for static linking of PXCP.dll
(1.94 KiB) Downloaded 290 times
