PCAN-USB Pro LIN Hardware Not Showing Up
ernieskaggs
Post by ernieskaggs » Thu 2. Jun 2016, 20:38
So we got one of those PCAN-USB Pro adapters and the can hardware seems to show up fine but the lin hardware doesn't show up 'PLIN-View Pro'. I was actually hoping to use it in Bosch busmaster but when I select the 'PEAK USB' under driver selection it says 'Listing hardware interfaces failed'. I checked the device manager and it shows up as LIN-Hardware. I connected the LIN bat and ground thinking it may not be powered but it still isn't showing up???? Using Windows 7.
HELP???????
Re: PCAN-USB Pro LIN Hardware Not Showing Up
Post by M.Maidhof » Fri 3. Jun 2016, 09:42
did you install the LIN drivers with our peakoemdrv.exe setup? This will install all necessary tools for the LIN part of the PCAN-USB-Pro hardware.
