Selected CAN-ID in Receive/Transmit window is not "sticky"
Username
Post by Username » Wed 21. Sep 2016, 21:30
When observing a particular CAN-ID in the receive transmit window, if a particular message is selected, it does not remain selected when additional messages are received, because the message list gets re-sorted upon each newly appearing message. This is very frustrating when attempting to observe a particular message in real-time. Is there an option to keep the selected CAN-ID highlighted and in focus, regardless of any other messages that are subsequently appearing on the bus?
Re: Selected CAN-ID in Receive/Transmit window is not "stick
Post by M.Maidhof » Thu 22. Sep 2016, 10:10
which software tool do you use, name and version will be helpfull.
Username
Post by Username » Fri 23. Sep 2016, 17:32
Sorry, forgot that bit:
P-CAN Explorer 5
5.4.1.898
Post by G.Lang » Mon 26. Sep 2016, 08:53
you can use the filter mechanism to filter the desired message and display it only.
or use a symbol file and add the variable to the watch window.
you can also use a symbol file + filter mechanism or you can add different filters or if you are working with many symbols use "marked symbols"
