Communication (Read Messages) discrepancy
abhishek1808
Post by abhishek1808 » Tue 1. Nov 2016, 10:16
Hello
We are using a miniPCIe (2 Channels).
The Card is on Bus 6 (Firmware 1.3.0)
The Development package is PCAN Basic API and development platform is .Net (C#, 4.2)
Somehow, I am not able to read a particular ID. Below is my code
 do
                //TPCANMsg msg = new TPCANMsg();
                statusCAN = PCANBasic.Read(channel, out msg, out _timeStamp);
                if (statusCAN == TPCANStatus.PCAN_ERROR_OK)
                    if (msg.ID == 0x18FF0221)
                        temp = (TwoBitStates)((msg.DATA[5] & 0x30) >> 4);// 0x30 = 0011 0000
                    else if (msg.ID == 0x18FF0421)
                        temp = msg.DATA[5];
                    else if (msg.ID == 0x18FF0921)
                       temp = msg.DATA[5];
                    else
                    { /* ignore other messages*/ }
                else
                     LogWriter.LogWrite("Component CAN Error in Reading: " + statusCAN.ToString() + _timeStamp.ToString());
            } while (!Convert.ToBoolean(statusCAN & TPCANStatus.PCAN_ERROR_QRCVEMPTY));
On PCAN View I can see all the 3 messages, but somehow msg.ID = 0x18FF0921 is never read. I put a breakpoint there.
But it never Enters the Else if statement.
All message are on same bus. Is the Code not okay?
Re: Communication (Read Messages) discrepancy
Post by PEAK-Support » Tue 1. Nov 2016, 12:18
Looks OK - but i would do it this way...
do
     switch (msg.ID)
        case 0x18FF0221:
        break;
        case  0x18FF0421:
            temp = msg.DATA[5];
        break;
        case 0x18FF0921:
            temp = msg.DATA[5];
        break;
        default:
        break;
   else
     LogWriter.LogWrite("Component CAN Error in Reading: " + statusCAN.ToString() + timeStamp.ToString());
abhishek1808
Post by abhishek1808 » Tue 1. Nov 2016, 12:30
Dear U.Wilhelm
I started with SWITCH but when i saw the example code from PEAK, I started using IF, ELSE thinking that maybe (which is a big maybe) I need to use IF, Else.
The Curious case is that I have a Dual Channel CAN Card from PEAK. The Other CAN channel works perfectly. :?: :?: :?: :?:
Post by PEAK-Support » Tue 1. Nov 2016, 12:50
Did you set any Filter? I do not see any reason why a card should not transmit exact this ID ...
Have you DEBUG the code, and set a Breakpoint in the switch when the case is called?
abhishek1808
Post by abhishek1808 » Tue 1. Nov 2016, 13:04
Hi
I have not set any filter!
I use breakpoints off course.
Will filter help? and why shall it?
Post by PEAK-Support » Tue 1. Nov 2016, 13:16
Filter will not fix your results. Please start your Application and connect to the Channel that loos this ID.
Now start PCAN-View and select the in use CAN Channel (you will see a info "hardware in use" - ignore it )
Now the PCAN-View works side by side to your application. All your Application send will be shown in PCAN-View. And all IDs you send with PCAN-View will also been transmitted to your Applications queue. Now send the ID from PCAN-View and see if it will be received.
abhishek1808
Post by abhishek1808 » Tue 1. Nov 2016, 14:08
I can see the message on PCAN View!
I have attached a Screen shot and using SWITCH CASE! Still the same issue.
Screen Shot of PCAN, whree the Message can be seen.
The actual code is attached here :
a.txt
Code
(3.53 KiB) Downloaded 622 times
I hope I have provided enough Information.
Post by PEAK-Support » Tue 1. Nov 2016, 15:26
1. I do not see if you connected the PCAN-View to the SAME CAN Hardware. If yes send the Frame one time from the PCAN-View to see if this will be received by your application. Thats what i say in my last post.
You say that PCAN-View see it - so the CAN PC Hardware read it - looks like no Hardware problem.
2. Download our sample, start it and see if the ID will be shown in the receive window.
http://www.peak-system.com/produktcd/De ... xample.exe
3. Please also send me the Initialize code to my by e-mail (support@peak-system.com)
