Peak.Lin.TLINMsgErrors.IdP when Calling Read()
colnewman
Post by colnewman » Thu 3. Nov 2016, 20:07
I've written a wrapper in C# to go around PLinApi.
I keep getting Peak.Lin.TLINMsgErrors.IdParityBit1 | Peak.Lin.TLINMsgErrors.SlaveNOtResponding returned from PLinApi.Read.
Not sure what IdParityBit is.
public class PeakLIN_Adapter : IAdapter
        private ushort handle = 1;
        byte hClient;
        private const ulong FRAME_FILTER_MASK = 0xFFFFFFFFFFFFFFFF;
        private const TLINHardwareMode HardwareMode = TLINHardwareMode.modMaster;
        private const int BaudRate = 9600;
        public void Initialize()
            var errorClient = PLinApi.RegisterClient("LIN API", (IntPtr)0, out hClient);
            if(errorClient == TLINError.errOK)
                if (HardwareAvailable(1))
                    //ClearClientsFromHardware();
                    var errorInit = PLinApi.InitializeHardware(hClient, handle, HardwareMode, BaudRate);
                    if (errorInit == TLINError.errOK)
                        var errorConnect = PLinApi.ConnectClient(hClient, handle);
                        if (errorConnect == TLINError.errOK)
                            var errorClientFIlter = PLinApi.SetClientFilter(hClient, handle, FRAME_FILTER_MASK);
                            if(errorClientFIlter != TLINError.errOK)
                                //** fix me throw exception
                        else
                    else
                else
            else
        public void Write(byte id, byte[] data)
            TLINMsg msg = new TLINMsg {FrameId = id, Data = data, ChecksumType = TLINChecksumType.cstAuto, Length = (byte)data.Length};
            Peak.Lin.PLinApi.CalculateChecksum(ref msg);
            PLinApi.Write(hClient, handle, ref msg);
        public bool Query(byte id, out byte[] data, byte NumberOfBytesToFetch)
            TLINMsg msgSend = new TLINMsg { FrameId = id, ChecksumType = TLINChecksumType.cstAuto, Length = NumberOfBytesToFetch, Direction = TLINDirection.dirSubscriberAutoLength};
            PLinApi.CalculateChecksum(ref msgSend);
            var errWrite = PLinApi.Write(hClient, handle, ref msgSend);
            if(errWrite != TLINError.errOK)
            TLINRcvMsg msgRcv;
            var run = true;
            TLINError errRead;
            do
                errRead = PLinApi.Read(hClient, out msgRcv);
                data = msgRcv.Data;
                if (msgRcv.Type != TLINMsgType.mstStandard)
                    continue;
                if(msgRcv.ErrorFlags != 0)
                    Log.Logger.Warning("{Class}.{Method} : Message Error Flag {flag}", nameof(PeakLIN_Adapter), nameof(Query),msgRcv.ErrorFlags);
                    return false;
                if (errRead == TLINError.errRcvQueueEmpty)
                    return false;
                else if(errRead == TLINError.errOK)
                    break;
                else
            while (run);
            if(errRead != TLINError.errOK)
            data = msgRcv.Data;
            return true;
        private bool IsInitilized()
            int baudRate = 0;
            PLinApi.GetHardwareParam(handle, TLINHardwareParam.hwpBaudrate, out baudRate, 1);
            int mode;
            PLinApi.GetHardwareParam(handle, TLINHardwareParam.hwpMode, out mode, 1);
            if ((TLINHardwareMode)mode == HardwareMode && baudRate == BaudRate)
                return true;
            return false;
        private void ClearClientsFromHardware()
            byte[] Buffer = new byte[255];
            PLinApi.GetHardwareParam(handle, TLINHardwareParam.hwpConnectedClients, Buffer, 255);
            foreach(var blah in Buffer)
                if(blah == 0)
                    continue;
                PLinApi.RemoveClient(blah);
                // PLinApi.GetHardwareParam(handle, TLINHardwareParam.hwpConnectedClients, Buffer, 255);
        private bool HardwareAvailable(ushort target)
            ushort []buff = new ushort[4096];
            ushort wBuffSize = 4096;
            ushort count;
            var error = PLinApi.GetAvailableHardware(buff, wBuffSize, out count);
            if(error != TLINError.errOK)
            var IsAvailable = buff.Any(x => x == target);
            return IsAvailable;
ETA fixed my first problem about initialization I need to call if after I connected, not before. Still have the second problem though.
Re: Peak.Lin.TLINMsgErrors.IdP when Calling Read()
Post by K.Wagner » Fri 4. Nov 2016, 08:51
colnewman wrote:I keep getting Peak.Lin.TLINMsgErrors.IdParityBit1 | Peak.Lin.TLINMsgErrors.SlaveNOtResponding returned from PLinApi.Read.
About IdParityBit1
I cannot see which ID you are using, but I guess you are using as ID a number between 0 and 63. Note that you have to use the ID with Parity. In order to calculate the parity of an ID you need to call the function PLinApi.GetPID() on the Frame ID. This means for example, if you want to sent the ID 0, you actually need to fill the ID member of the frame with 128.
About SlaveNotResponding
Since the ID is not recognized by your slave, it doesn't respond, so you get also the error "Slave not responding". Note that this error is also received when there is no slave at all to communicate with, and also if you use the PCAN-USB Pro FD without power supply (12 volts).
colnewman wrote:ETA fixed my first problem about initialization I need to call if after I connected, not before. Still have the second problem though.
Sorry but I don't understand this sentence.
colnewman
Post by colnewman » Thu 1. Dec 2016, 20:52
K.Wagner wrote:Hello,
About IdParityBit1
Sorry for not responding I have just recently gotten back to this project. That worked, Thank you. It also solved another problem I ha,d which was that my publisher messages didn't seem to be working writing to my slave.
Sorry, It would only mean something if you saw my original post before I edited.
