PCAN USB not powering on
USB to CAN Interface
Prableen
Post by Prableen » Mon 28. Nov 2016, 08:33
MY PCAN USB adapter was working perfectly fine till last friday, Today morning I plugged it into my PC and the red LED won't turn on! I have tried restarting my PC, using a different PC, uninstalling and reinstalling the PCAN drivers but with no luck!
On the hardware, I pried open the case and checked the power pins on the board, it is receiving 5V at the input from the USB.
Please help me out! I am in dire need of the device for my project!
Prableen
Re: PCAN USB not powering on
Post by M.Maidhof » Mon 28. Nov 2016, 17:22
when the LED will not be active, after you have successfully installed the driver, it looks like a problem with the USB controller or device firmware. You can send us the module for a system check.
dvdar2
Post by dvdar2 » Mon 16. May 2022, 21:44
I have the same problem, could you share destination post address please? I would like to sent to you our PCAN-USB device. In advance, thank you, best regards.
