coupling PCAN Router Pro and PCAN Mio
Hello everybody
I am charged with new controlling system using PCAN-Router Pro and PCAN-Mio which will work together. My question is how can i couple the two devices?
Thanks in advance
Thanks in advance
Re: coupling PCAN Router Pro and PCAN Mio
With a CAN Bus Cable!
Dear U.Wilhelm
Thank you for the fast reply but i would tell you that i have precisely searched on an adapter which can connect PCAN-Router Pro (IPEH00221201440) with PCAN-Mio automotive type (IPEH-002187-A) but unfortunatly i have found nothing, so it is nice if I can know how to establish the communication between D-sub(9 pins) connector and 32 pins connector. Whatever is the method.
Thanks for every one
sorry -- but i do not understand your question?!?
You do not know how to connect the two units via CAN ? Is this correct ?
Or do you not know how to CONFIGURE the 2 units via CAN?
Please try to explain your request in a way we could help you - Thank you !
Do you have a physical problem -(cable / connector etc.) or a Software Problem (configuration etc.)
For configuration you need a CAN Interface from PEAK and the free available PPCAN-Editor (run only on Windows systems (Vista/W7/W8/W10)
I have already installed PPCAN-Editor and it is working properly but i need to connect the two units with each other.
I have a physical problem -(cable / connector etc.)
Take a look into the manual of Router Pro - Page 9 LINK
And into the manual of PCAN-MIO Page 23 LINK
Connect the CAN0 of the MIO Automotive (A14-CAN_L/A13-CAN_H) and the CAN1 of the Router Pro (D-SUB DPin2-CAN_L / Pin7-CAN_H) to the PC CAN Interface (D-SUB - Pin2-CAN_L / Pin7-CAN_H) always CAN_H to CAN_H and CAN_L to CAN_L. Terminate the CAN Bus with a 120 Ohm Resistor on each end between CAN_H and CAN_L.
thank you for valuable supporting, that is what i need for now, i will try connect them according to your instruction and start configuration.
