The definition of timestamp in struct TPCANRdMsg
yangming0
Post by yangming0 » Tue 17. Jan 2017, 03:55
1. What is the reference of the timestamp in struct "TPCANRdMsg", for example epoch?
2. Is there any C++11 standard library that can provide the same reference of the timestamp in struct "TPCANRdMsg"?
thx
Re: The definition of timestamp in struct TPCANRdMsg
Post by M.Maidhof » Tue 17. Jan 2017, 10:47
the driver time is based on the Linux Jiffies, see pcan_main.c line 2104 for more details:
/* request time in msec, fast */
u32 get_mtime(void)
	/* return (jiffies / HZ) * 1000; */
	return jiffies_to_msecs(jiffies);
yangming0
Post by yangming0 » Wed 18. Jan 2017, 03:49
M.Maidhof wrote:Hi,
u32 get_mtime(void)
Thx for your answer. There is another question: how can I use "get_mtime(void)" or "jiffies_to_msecs(jiffies)" in my code (in user space)?
yangming0
S.Grosjean
Post by S.Grosjean » Wed 18. Jan 2017, 17:35
These calls are Kernel specific. If you want to get time in the same way than the pcan driver, your application should use "struct timeval" objects and "gettimeofday()" from standard libc.
Stéphane
— Stéphane
psedlos
Post by psedlos » Fri 21. Feb 2020, 11:59
As nobody closed this topic, let me ask for advice regard Timestamp - what is best way to convert timestamp to epoch, or any other universla time? Best in Python or Python-supported
S.Grosjean
Post by S.Grosjean » Fri 21. Feb 2020, 15:16
TPCANRdMsg struct type defines "dwTime" as a number of milliseconds. This counter is a 32-bit value so it's obvious that it can't contain any epoch time. It should be used to compute delays between received messages only. These types are kept for compatibility only. If you'd like to deal with more modern timestamps, you'll have to switch to the other and newer API of the driver. Please read the documentation provided by the package.
— Stéphane
