Having Trouble Sending CAN Messages
luliily
Post by luliily » Sat 4. Feb 2017, 07:58
I'm an new user of PEAK-CAN.
When I use PCAN-ISO TP API to send a message,which's configurated correctly,and the CANTP_Initialize function returns PCANTP_ERROR_OK.But CANTP_Write function PCANTP_ERROR_NOT_INITIALIZED!I'm so confused here.
Thasnk you
Best Wishes~
void CUDSDlg::OnBnClickedButtonBoschTp()
	TPCANTPMsg MsgTP_READ;
	TPCANTPMsg MsgTP_WRITE;
	TPCANTPStatus result;
	MsgTP_WRITE.SA = 0xFA;
	MsgTP_WRITE.TA = 0x00;
	MsgTP_WRITE.TA_TYPE = PCANTP_ADDRESSING_PHYSICAL;
	MsgTP_WRITE.RA = 0x00;
	MsgTP_WRITE.IDTYPE = PCANTP_ID_CAN_29BIT;
	MsgTP_WRITE.FORMAT = PCANTP_FORMAT_NORMAL;
	MsgTP_WRITE.LEN = 0x02;
	MsgTP_WRITE.DATA[0] = 0x10;
	MsgTP_WRITE.DATA[1] = 0x81;
	MsgTP_WRITE.MSGTYPE = PCANTP_MESSAGE_DIAGNOSTIC;
	result = CANTP_Initialize(PCANTP_USBBUS1, PCANTP_BAUD_250K);//Degug Point A: result == 0x00;
	if (result != PCANTP_ERROR_OK)
		MessageBox(L"Initialize Fail.");
		return;
	result = CANTP_Write(PCANTP_USBBUS1, &MsgTP_WRITE);//Degug Point B: result == 0x01; It is contradict with Degug Point A.
		CString str;
		str.Format(L"Error Code = %d", result);
		str += L",Send Failure.";
		MessageBox(str);
		PostMessage(WM_CLOSE);
F.Vergnaud
Re: Having Trouble Sending CAN Messages
Post by F.Vergnaud » Mon 6. Feb 2017, 09:48
Hello Luliily,
The message you are trying to send requires a mapping (29-bits with Normal addressing format). When you try to transmit the message, the API fails to find it stating that the mapping is not initialized (indeed the error code could be clearer).
You either need to use FIXED NORMAL addressing format for your message (as no mapping is required with this format) or add the corresponding mapping using CANTP_AddMapping function.
luliily
Post by luliily » Wed 1. Mar 2017, 10:17
I add the function CANTP_AddMapping which returns code 0.And the function CANTP_Write returns code 0,too.
But the CAN message that the API acctually send is quite weird.Is there something wrong?
Another question,when the program runs to function CANTP_Uninitialize,it means CANTP_Read receives message,right?But the data stored in MsgTP_READ doesn't match the actual message.
Here is my code:
	TPCANTPMsg MsgTP_READ = {};
	TPCANTPMsg MsgTP_WRITE = {};
	MsgTP_WRITE.LEN = 2;
	result = CANTP_Initialize(PCANTP_USBBUS1, PCANTP_BAUD_250K);//Degug Point A: result == 0x00;---OK
		return;
	result = CANTP_AddMapping(PCANTP_USBBUS1,
		0x18DA00FA,
		0x18DAFA00,
		PCANTP_ID_CAN_29BIT,
		PCANTP_FORMAT_NORMAL,
		PCANTP_MESSAGE_DIAGNOSTIC,
		0xFA,
		0x00,
		PCANTP_ADDRESSING_PHYSICAL,
		0x00);
	if (result != PCANTP_ERROR_OK)//New Degug Point C: result == 0x00;---OK
		MessageBox(L"Mapping Fail.");
		return;
	result = CANTP_Write(PCANTP_USBBUS1, &MsgTP_WRITE);//Degug Point B: result == 0x00;---OK---But the CAN message is wrong.
		CString str;
		MessageBox(str);
	BOOL bStop = TRUE;
	while (bStop)
		result = CANTP_Read(PCANTP_USBBUS1, &MsgTP_READ);//It receives wired data,all zero.
		if (result == PCANTP_ERROR_OK)
			bStop = FALSE;
	result = CANTP_Uninitialize(PCANTP_USBBUS1);
		MessageBox(L"Uninitialize Fail.");
		return;
Thanks for your attention.Best wishes.
F.Vergnaud
Post by F.Vergnaud » Wed 1. Mar 2017, 12:10
First thing I see from the CAN IDs you are using is that you are confusing NORMAL addressing format and FIXED NORMAL addressing format. Fixed Normal addressing format is well defined in the ISO-TP standard: based on the network addressing information (SA, TA, priority, etc.) it will create a specific CAN ID. Since the API will try to decode those specific CAN IDs first when receiving a 29 bits CAN message, it can lead to unforeseen behaviour.
Here is your code simplified with the use of FIXED NORMAL addressing :
	MsgTP_WRITE.FORMAT = PCANTP_FORMAT_FIXED_NORMAL;
      return;
      CString str;
      MessageBox(str);
   BOOL bStop = TRUE;
   while (bStop)
         bStop = FALSE;
      return;
F.Vergnaud
Post by F.Vergnaud » Wed 1. Mar 2017, 12:15
I forgot to mention that the first message that you will read is the confirmation of your transmission.
You need to check the MSGTYPE value which should be PCANTP_MESSAGE_REQUEST_CONFIRMATION (and also always check the RESULT value to ensure that the transmission was ok).
Then the following message should be the response.
luliily
Post by luliily » Thu 2. Mar 2017, 10:26
I used the code you wrote.But the result is still the same,like yesterday.
Screenshot:
Code:
		return;
		CString str;
		MessageBox(str);
	BOOL bStop = TRUE;
	while (bStop)
		result = CANTP_Read(PCANTP_USBBUS1, &MsgTP_READ);//---OK
			if (MsgTP_READ.MSGTYPE != PCANTP_MESSAGE_REQUEST_CONFIRMATION)//matching the actual message---OK
				bStop = FALSE;
				break;
		return;
F.Vergnaud
Post by F.Vergnaud » Thu 2. Mar 2017, 11:07
I've copied/pasted your code and validated your code: the message sent on the CAN bus contains the correct data
ID=0x18DA00FA, Length=8, Data=02 10 81 55 55 55 55 55
Your result shows that the sent message had a length of 1 and the data was 0x00.. as if the content of the variable MsgTP_WRITE was not set correctly. You should check it while debugging.
Otherwise which version of the ISO-TP and PCANBasic API do you use ? Current versions are respectively 2.0.0.63 and 4.1.0.96. You can get ISO-TP version info with the following function :
	char buf[256];
	CANTP_GetValue(PCANTP_NONEBUS, PCANTP_PARAM_API_VERSION, buf, sizeof(buf));
	printf("ISO-TP API = %s", buf);
luliily
Post by luliily » Mon 6. Mar 2017, 05:28
PROBLEM SOLVED!!THANK YOU!!!
My Basic and TP API Version was outdated.Then I update the TP API and BASIC API to the latest version.The message is finally normal.
Again,thanks for your patience.Thank you very much!
