Kernel OOPS of SocketCAN for PCAN-PCI/104-Express 2 Channels
georgekang
Post by georgekang » Thu 9. Mar 2017, 10:25
While I tried to enable the CAN network interface for the PCAN-PCI/104-Express, the following Kernel OOPS messages will be produced. Any suggestion about this?
Thanks a lot.
The related information is listed as follows:
Hardware: ADLINK CM920
 - Intel® Core™ i7-3517UE 1.7GHz
 Operating System: Linux 4.4.12
- CAN Interface Enable Command:
    ip link add dev can0 type can
- Kernel OOPS:
[  344.872022] BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
[  344.873156] IP: [<ffffffff815500a0>] can_validate+0x0/0x50
[  344.874299] PGD 76926067 PUD 76a9a067 PMD 0
[  344.875438] Oops: 0000 [#1] PREEMPT SMP
[  344.876567] Modules linked in:
[  344.877679] CPU: 0 PID: 1245 Comm: ip Not tainted 4.4.12-rt19+ #5
[  344.878800] Hardware name: To be filled by O.E.M. To be filled by O.E.M./ChiefRiver, BIOS 4.6.5 04/11/2013
[  344.879954] task: ffff880078adcf80 ti: ffff880076e10000 task.ti: ffff880076e10000
[  344.881106] RIP: 0010:[<ffffffff815500a0>]  [<ffffffff815500a0>] can_validate+0x0/0x50
[  344.882280] RSP: 0018:ffff880076e13920  EFLAGS: 00010286
[  344.883451] RAX: ffffffff815500a0 RBX: 0000000000000000 RCX: 0000000000000000
[  344.884634] RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff880076e13a50
[  344.885805] RBP: ffff880076e13bb8 R08: ffffffff818be670 R09: ffff880076e13a18
[  344.886963] R10: 000000007ffff000 R11: ffff880076e14000 R12: 0000000000000000
[  344.888116] R13: ffff8800769bc200 R14: ffff880076e139c0 R15: ffffffff81cf5ee0
[  344.889265] FS:  00007f597bbb2700(0000) GS:ffff880100200000(0000) knlGS:0000000000000000
[  344.890434] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[  344.891596] CR2: 0000000000000028 CR3: 00000000768b3000 CR4: 00000000001406f0
[  344.892774] Stack:
[  344.893936]  ffffffff81699094 ffff8800769bc224 0000000000000005 ffff880076e13978
[  344.895146]  ffffffff81342640 ffff880076e139e8 ffffffff813426f2 ffff880076e13978
[  344.896354]  ffffffff81696614 0000000000000000 0000000000000000 ffff880076e13bb8
[  344.897560] Call Trace:
[  344.898729]  [<ffffffff81699094>] ? rtnl_newlink+0x1e4/0x890
[  344.899905]  [<ffffffff81342640>] ? nla_parse+0xa0/0x100
[  344.901063]  [<ffffffff813426f2>] ? nla_strlcpy+0x52/0x60
[  344.902216]  [<ffffffff81696614>] ? rtnl_link_ops_get+0x34/0x50
[  344.903364]  [<ffffffff81698ff6>] ? rtnl_newlink+0x146/0x890
[  344.904503]  [<ffffffff81697bbf>] rtnetlink_rcv_msg+0x7f/0x200
[  344.905628]  [<ffffffff81171900>] ? __kmalloc_node_track_caller+0x30/0x270
[  344.906769]  [<ffffffff81697b40>] ? rtnetlink_rcv+0x30/0x30
[  344.907901]  [<ffffffff816b6d42>] netlink_rcv_skb+0x92/0xb0
[  344.909033]  [<ffffffff81697b33>] rtnetlink_rcv+0x23/0x30
[  344.910158]  [<ffffffff816b6751>] netlink_unicast+0x161/0x200
[  344.911267]  [<ffffffff816b6acb>] netlink_sendmsg+0x2db/0x390
[  344.912355]  [<ffffffff8166d5c3>] sock_sendmsg+0x33/0x40
[  344.913429]  [<ffffffff8166df60>] ___sys_sendmsg+0x240/0x250
[  344.914501]  [<ffffffff8166e0bc>] ? ___sys_recvmsg+0x14c/0x1c0
[  344.915574]  [<ffffffff81339053>] ? __this_cpu_preempt_check+0x13/0x20
[  344.916646]  [<ffffffff81339037>] ? debug_smp_processor_id+0x17/0x20
[  344.917706]  [<ffffffff8112f0b7>] ? __lru_cache_add+0x57/0xa0
[  344.918760]  [<ffffffff817c8c61>] ? _raw_write_unlock+0x11/0x30
[  344.919819]  [<ffffffff8114d6b4>] ? handle_mm_fault+0xab4/0x1180
[  344.920860]  [<ffffffff811507c8>] ? __vma_link_rb+0xf8/0x110
[  344.921883]  [<ffffffff8166e76d>] __sys_sendmsg+0x3d/0x70
[  344.922900]  [<ffffffff8166e7ad>] SyS_sendmsg+0xd/0x20
[  344.923914]  [<ffffffff817c9257>] entry_SYSCALL_64_fastpath+0x12/0x66
[  344.924946] Code: 00 00 20 75 e6 b8 ea ff ff ff 5d c3 f6 87 78 08 00 00 20 75 f0 83 a7 70 08 00 00 df eb d4 b8 f0 ff ff ff 5d c3 66 0f 1f 44 00 00 <48> 8b 46 28 55 48 89 e5 48 85 c0 74 1f 8b 50 08 23 50 04 89 d0
[  344.927395] RIP  [<ffffffff815500a0>] can_validate+0x0/0x50
[  344.928492]  RSP <ffff880076e13920>
[  344.929565] CR2: 0000000000000028
[  344.931148] ---[ end trace 2af6c0cdccfae61c ]---
[  344.933466] ip (1245) used greatest stack depth: 12384 bytes left
S.Grosjean
Re: Kernel OOPS of SocketCAN for PCAN-PCI/104-Express 2 Chan
Post by S.Grosjean » Thu 9. Mar 2017, 16:57
Can you please tell us which driver are you running? Did you download our pcan driver from our website or do you run the mainline one, please?
Stéphane
— Stéphane
georgekang
Post by georgekang » Fri 10. Mar 2017, 03:32
I use the SocketCAN of Linux kernel mainline.
Here is the full dmseg including booting messages and kernel OOPS.
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.12-rt19+ (georgekang@workstation) (gcc version 5.4.1 20160904 (Ubuntu 5.4.1-2ubuntu1~16.04) ) #5 SMP PREEMPT Thu Mar 9 15:00:34 CST 2017
[    0.000000] Command line: BOOT_IMAGE=/bzImage root=/dev/sdb2 rootwait console=tty1 isolcpus=1
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Supporting XSAVE feature 0x01: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x02: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x04: 'AVX registers'
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.000000] x86/fpu: Using 'eager' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001fffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000020000000-0x00000000201fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000020200000-0x0000000040003fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000040004000-0x0000000040004fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000040005000-0x0000000077f83fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000077f84000-0x00000000782a4fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000782a5000-0x00000000783bafff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000783bb000-0x0000000078778fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000078779000-0x0000000078779fff] usable
[    0.000000] BIOS-e820: [mem 0x000000007877a000-0x00000000787bcfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000787bd000-0x0000000078e01fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000078e02000-0x0000000078ff1fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000078ff2000-0x0000000078ffffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000079800000-0x000000007d9fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x00000001005fffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.31 by American Megatrends
[    0.000000] efi:  ACPI=0x783ad000  ACPI 2.0=0x783ad000  SMBIOS=0xf04c0  MPS=0xfd470
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: To be filled by O.E.M. To be filled by O.E.M./ChiefRiver, BIOS 4.6.5 04/11/2013
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x100600 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-DFFFF uncachable
[    0.000000]   E0000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask F00000000 write-back
[    0.000000]   1 base 100000000 mask FFFC00000 write-back
[    0.000000]   2 base 100400000 mask FFFE00000 write-back
[    0.000000]   3 base 080000000 mask F80000000 uncachable
[    0.000000]   4 base 07C000000 mask FFC000000 uncachable
[    0.000000]   5 base 07A000000 mask FFE000000 uncachable
[    0.000000]   6 base 079800000 mask FFF800000 uncachable
[    0.000000]   7 disabled
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT
[    0.000000] e820: update [mem 0x79800000-0xffffffff] usable ==> reserved
[    0.000000] e820: last_pfn = 0x79000 max_arch_pfn = 0x400000000
[    0.000000] found SMP MP-table at [mem 0x000fd800-0x000fd80f] mapped at [ffff8800000fd800]
[    0.000000] Scanning 1 areas for low memory corruption
[    0.000000] Base memory trampoline at [ffff880000098000] 98000 size 24576
[    0.000000] BRK [0x01ef3000, 0x01ef3fff] PGTABLE
[    0.000000] BRK [0x01ef4000, 0x01ef4fff] PGTABLE
[    0.000000] BRK [0x01ef5000, 0x01ef5fff] PGTABLE
[    0.000000] BRK [0x01ef6000, 0x01ef6fff] PGTABLE
[    0.000000] BRK [0x01ef7000, 0x01ef7fff] PGTABLE
[    0.000000] BRK [0x01ef8000, 0x01ef8fff] PGTABLE
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000783AD000 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x00000000783AD070 000064 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x00000000783B5E38 00010C (v05 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x00000000783AD170 008CC8 (v02 ALASKA A M I    00000021 INTL 20051117)
[    0.000000] ACPI: FACS 0x00000000783B9080 000040
[    0.000000] ACPI: APIC 0x00000000783B5F48 000062 (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0x00000000783B5FB0 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: MCFG 0x00000000783B5FF8 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.000000] ACPI: HPET 0x00000000783B6038 000038 (v01 ALASKA A M I    01072009 AMI. 00000005)
[    0.000000] ACPI: SSDT 0x00000000783B6070 000495 (v01 IdeRef IdeTable 00001000 INTL 20091112)
[    0.000000] ACPI: SSDT 0x00000000783B6508 000A7E (v01 PmRef  CpuPm    00003000 INTL 20051117)
[    0.000000] ACPI: DMAR 0x00000000783B6F88 0000B0 (v01 INTEL  SNB      00000001 INTL 00000001)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x00000001005fffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x1005f9000-0x1005fcfff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000001005fffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000001fffffff]
[    0.000000]   node   0: [mem 0x0000000020200000-0x0000000040003fff]
[    0.000000]   node   0: [mem 0x0000000040005000-0x0000000077f83fff]
[    0.000000]   node   0: [mem 0x0000000078779000-0x0000000078779fff]
[    0.000000]   node   0: [mem 0x00000000787bd000-0x0000000078e01fff]
[    0.000000]   node   0: [mem 0x0000000078ff2000-0x0000000078ffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000001005fffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x00000001005fffff]
[    0.000000] On node 0 totalpages: 493941
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 25 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 7632 pages used for memmap
[    0.000000]   DMA32 zone: 488407 pages, LIFO batch:31
[    0.000000]   Normal zone: 24 pages used for memmap
[    0.000000]   Normal zone: 1536 pages, LIFO batch:0
[    0.000000] Reserving Intel graphics stolen memory at 0x79a00000-0x7d9fffff
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] smpboot: Allowing 2 CPUs, 0 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x20000000-0x201fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x40004000-0x40004fff]
[    0.000000] PM: Registered nosave memory: [mem 0x77f84000-0x782a4fff]
[    0.000000] PM: Registered nosave memory: [mem 0x782a5000-0x783bafff]
[    0.000000] PM: Registered nosave memory: [mem 0x783bb000-0x78778fff]
[    0.000000] PM: Registered nosave memory: [mem 0x7877a000-0x787bcfff]
[    0.000000] PM: Registered nosave memory: [mem 0x78e02000-0x78ff1fff]
[    0.000000] PM: Registered nosave memory: [mem 0x79000000-0x797fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x79800000-0x7d9fffff]
[    0.000000] PM: Registered nosave memory: [mem 0x7da00000-0xf7ffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.000000] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.000000] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] e820: [mem 0x7da00000-0xf7ffffff] available for PCI devices
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.000000] setup_percpu: NR_CPUS:64 nr_cpumask_bits:64 nr_cpu_ids:2 nr_node_ids:1
[    0.000000] PERCPU: Embedded 32 pages/cpu @ffff880100200000 s92312 r8192 d30568 u1048576
[    0.000000] pcpu-alloc: s92312 r8192 d30568 u1048576 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1
[    0.000000] Built 1 zonelists in Node order, mobility grouping on.  Total pages: 486196
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/bzImage root=/dev/sdb2 rootwait console=tty1 isolcpus=1
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Calgary: detecting Calgary via BIOS EBDA area
[    0.000000] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.000000] Memory: 1669500K/1975764K available (7990K kernel code, 1018K rwdata, 2588K rodata, 1024K init, 936K bss, 306264K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=2.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=2
[    0.000000] NR_IRQS:4352 nr_irqs:440 16
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty1] enabled
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns
[    0.000000] hpet clockevent registered
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2194.976 MHz processor
[    0.000040] Calibrating delay loop (skipped), value calculated using timer frequency.. 4389.95 BogoMIPS (lpj=2194976)
[    0.000052] pid_max: default: 32768 minimum: 301
[    0.000060] ACPI: Core revision 20150930
[    0.007350] ACPI: 3 ACPI AML tables successfully acquired and loaded
[    0.008331] Security Framework initialized
[    0.008338] SELinux:  Initializing.
[    0.008350] SELinux:  Starting in permissive mode
[    0.008582] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.009319] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.009658] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.009668] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.009889] Initializing cgroup subsys freezer
[    0.009919] CPU: Physical Processor ID: 0
[    0.009924] CPU: Processor Core ID: 0
[    0.009933] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.009939] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.010468] mce: CPU supports 7 MCE banks
[    0.010486] CPU0: Thermal monitoring enabled (TM1)
[    0.010508] process: using mwait in idle threads
[    0.010516] Last level iTLB entries: 4KB 512, 2MB 8, 4MB 8
[    0.010521] Last level dTLB entries: 4KB 512, 2MB 32, 4MB 32, 1GB 0
[    0.011192] Freeing SMP alternatives memory: 28K (ffffffff81e00000 - ffffffff81e07000)
[    0.020075] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.030088] TSC deadline timer enabled
[    0.030093] smpboot: CPU0: Intel(R) Core(TM) i7-3517UE CPU @ 1.70GHz (family: 0x6, model: 0x3a, stepping: 0x9)
[    0.030132] Performance Events: PEBS fmt1+, 16-deep LBR, IvyBridge events, full-width counters, Intel PMU driver.
[    0.030168] ... version:                3
[    0.030173] ... bit width:              48
[    0.030178] ... generic registers:      8
[    0.030183] ... value mask:             0000ffffffffffff
[    0.030188] ... max period:             0000ffffffffffff
[    0.030193] ... fixed-purpose events:   3
[    0.030198] ... event mask:             00000007000000ff
[    0.039192] x86: Booting SMP configuration:
[    0.039199] .... node  #0, CPUs:      #1
[    0.042361] x86: Booted up 1 node, 2 CPUs
[    0.042372] smpboot: Total of 2 processors activated (8779.90 BogoMIPS)
[    0.044507] devtmpfs: initialized
[    0.045465] PM: Registering ACPI NVS region [mem 0x782a5000-0x783bafff] (1138688 bytes)
[    0.045493] PM: Registering ACPI NVS region [mem 0x7877a000-0x787bcfff] (274432 bytes)
[    0.045593] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.046506] RTC time: 15:04:22, date: 03/09/17
[    0.046646] NET: Registered protocol family 16
[    0.046989] kworker/u4:0 (34) used greatest stack depth: 15048 bytes left
[    0.047055] kworker/u4:0 (29) used greatest stack depth: 14704 bytes left
[    0.047081] kworker/u4:0 (33) used greatest stack depth: 14240 bytes left
[    0.047100] kworker/u4:0 (32) used greatest stack depth: 13920 bytes left
[    0.050470] cpuidle: using governor ladder
[    0.054453] cpuidle: using governor menu
[    0.054558] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.054567] ACPI: bus type PCI registered
[    0.054638] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.054649] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.054658] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[    0.054735] PCI: Using configuration type 1 for base access
[    0.054889] perf_event_intel: PMU erratum BJ122, BV98, HSD29 workaround disabled, HT off
[    0.066616] ACPI: Added _OSI(Module Device)
[    0.066626] ACPI: Added _OSI(Processor Device)
[    0.066631] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.066637] ACPI: Added _OSI(Processor Aggregator Device)
[    0.070702] ACPI: Executed 1 blocks of module-level executable AML code
[    0.074036] ACPI: Dynamic OEM Table Load:
[    0.074050] ACPI: SSDT 0xFFFF8800789AC000 00083B (v01 PmRef  Cpu0Cst  00003001 INTL 20051117)
[    0.074818] ACPI: Dynamic OEM Table Load:
[    0.074828] ACPI: SSDT 0xFFFF8800770D0800 000119 (v01 PmRef  ApCst    00003000 INTL 20051117)
[    0.075678] ACPI: Interpreter enabled
[    0.075697] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20150930/hwxface-580)
[    0.075710] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S3_] (20150930/hwxface-580)
[    0.075723] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S4_] (20150930/hwxface-580)
[    0.075736] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S5_] (20150930/hwxface-580)
[    0.075746] ACPI: (supports S0 S1)
[    0.075752] ACPI: Using IOAPIC for interrupt routing
[    0.075808] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.087695] ACPI: Power Resource [FN00] (off)
[    0.087843] ACPI: Power Resource [FN01] (off)
[    0.087984] ACPI: Power Resource [FN02] (off)
[    0.088124] ACPI: Power Resource [FN03] (off)
[    0.088265] ACPI: Power Resource [FN04] (off)
[    0.089104] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.089116] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.089399] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug PME]
[    0.089581] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability]
[    0.089633] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.089991] PCI host bridge to bus 0000:00
[    0.089999] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.090006] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.090013] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.090022] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.090031] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.090040] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.090049] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.090058] pci_bus 0000:00: root bus resource [mem 0x7da00000-0xfeafffff window]
[    0.090067] pci_bus 0000:00: root bus resource [bus 00-3e]
[    0.090084] pci 0000:00:00.0: [8086:0154] type 00 class 0x060000
[    0.090226] pci 0000:00:02.0: [8086:0166] type 00 class 0x030000
[    0.090245] pci 0000:00:02.0: reg 0x10: [mem 0xf5000000-0xf53fffff 64bit]
[    0.090253] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.090259] pci 0000:00:02.0: reg 0x20: [io  0xe000-0xe03f]
[    0.090473] pci 0000:00:16.0: [8086:1c3a] type 00 class 0x078000
[    0.090515] pci 0000:00:16.0: reg 0x10: [mem 0xf7d2b000-0xf7d2b00f 64bit]
[    0.090601] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.090788] pci 0000:00:16.3: [8086:1c3d] type 00 class 0x070002
[    0.090820] pci 0000:00:16.3: reg 0x10: [io  0xe140-0xe147]
[    0.090830] pci 0000:00:16.3: reg 0x14: [mem 0xf7d29000-0xf7d29fff]
[    0.091047] pci 0000:00:19.0: [8086:1502] type 00 class 0x020000
[    0.091084] pci 0000:00:19.0: reg 0x10: [mem 0xf7d00000-0xf7d1ffff]
[    0.091095] pci 0000:00:19.0: reg 0x14: [mem 0xf7d28000-0xf7d28fff]
[    0.091106] pci 0000:00:19.0: reg 0x18: [io  0xe060-0xe07f]
[    0.091170] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[    0.091235] pci 0000:00:19.0: System wakeup disabled by ACPI
[    0.091337] pci 0000:00:1a.0: [8086:1c2d] type 00 class 0x0c0320
[    0.091373] pci 0000:00:1a.0: reg 0x10: [mem 0xf7d27000-0xf7d273ff]
[    0.091464] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.091587] pci 0000:00:1a.0: System wakeup disabled by ACPI
[    0.091724] pci 0000:00:1b.0: [8086:1c20] type 00 class 0x040300
[    0.091758] pci 0000:00:1b.0: reg 0x10: [mem 0xf7d20000-0xf7d23fff 64bit]
[    0.091829] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.091896] pci 0000:00:1b.0: System wakeup disabled by ACPI
[    0.092017] pci 0000:00:1c.0: [8086:1c10] type 01 class 0x060400
[    0.092149] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.092223] pci 0000:00:1c.0: System wakeup disabled by ACPI
[    0.092408] pci 0000:00:1c.1: [8086:1c12] type 01 class 0x060400
[    0.092539] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[    0.092617] pci 0000:00:1c.1: System wakeup disabled by ACPI
[    0.092688] pci 0000:00:1c.2: [8086:1c14] type 01 class 0x060400
[    0.092817] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.092888] pci 0000:00:1c.2: System wakeup disabled by ACPI
[    0.092990] pci 0000:00:1c.3: [8086:1c16] type 01 class 0x060400
[    0.093122] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.093195] pci 0000:00:1c.3: System wakeup disabled by ACPI
[    0.093322] pci 0000:00:1c.4: [8086:1c18] type 01 class 0x060400
[    0.093422] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.093489] pci 0000:00:1c.4: System wakeup disabled by ACPI
[    0.093566] pci 0000:00:1c.6: [8086:1c1c] type 01 class 0x060400
[    0.093716] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[    0.093784] pci 0000:00:1c.6: System wakeup disabled by ACPI
[    0.093855] pci 0000:00:1d.0: [8086:1c26] type 00 class 0x0c0320
[    0.093893] pci 0000:00:1d.0: reg 0x10: [mem 0xf7d26000-0xf7d263ff]
[    0.093985] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.094066] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.094135] pci 0000:00:1f.0: [8086:1c4f] type 00 class 0x060100
[    0.094368] pci 0000:00:1f.2: [8086:1c01] type 00 class 0x01018f
[    0.094395] pci 0000:00:1f.2: reg 0x10: [io  0xe130-0xe137]
[    0.094405] pci 0000:00:1f.2: reg 0x14: [io  0xe120-0xe123]
[    0.094415] pci 0000:00:1f.2: reg 0x18: [io  0xe110-0xe117]
[    0.094425] pci 0000:00:1f.2: reg 0x1c: [io  0xe100-0xe103]
[    0.094435] pci 0000:00:1f.2: reg 0x20: [io  0xe0f0-0xe0ff]
[    0.094445] pci 0000:00:1f.2: reg 0x24: [io  0xe0e0-0xe0ef]
[    0.094587] pci 0000:00:1f.3: [8086:1c22] type 00 class 0x0c0500
[    0.094616] pci 0000:00:1f.3: reg 0x10: [mem 0xf7d25000-0xf7d250ff 64bit]
[    0.094642] pci 0000:00:1f.3: reg 0x20: [io  0xe040-0xe05f]
[    0.094780] pci 0000:00:1f.5: [8086:1c09] type 00 class 0x010185
[    0.094809] pci 0000:00:1f.5: reg 0x10: [io  0xe0d0-0xe0d7]
[    0.094820] pci 0000:00:1f.5: reg 0x14: [io  0xe0c0-0xe0c3]
[    0.094830] pci 0000:00:1f.5: reg 0x18: [io  0xe0b0-0xe0b7]
[    0.094840] pci 0000:00:1f.5: reg 0x1c: [io  0xe0a0-0xe0a3]
[    0.094850] pci 0000:00:1f.5: reg 0x20: [io  0xe090-0xe09f]
[    0.094860] pci 0000:00:1f.5: reg 0x24: [io  0xe080-0xe08f]
[    0.095070] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.095081] pci 0000:00:1c.0:   bridge window [io  0xd000-0xdfff]
[    0.095087] pci 0000:00:1c.0:   bridge window [mem 0xf7200000-0xf7bfffff]
[    0.095096] pci 0000:00:1c.0:   bridge window [mem 0xf1e00000-0xf27fffff 64bit pref]
[    0.095174] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.095184] pci 0000:00:1c.1:   bridge window [io  0xc000-0xcfff]
[    0.095190] pci 0000:00:1c.1:   bridge window [mem 0xf6800000-0xf71fffff]
[    0.095199] pci 0000:00:1c.1:   bridge window [mem 0xf1400000-0xf1dfffff 64bit pref]
[    0.095277] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.095287] pci 0000:00:1c.2:   bridge window [io  0xb000-0xbfff]
[    0.095293] pci 0000:00:1c.2:   bridge window [mem 0xf5e00000-0xf67fffff]
[    0.095302] pci 0000:00:1c.2:   bridge window [mem 0xf0a00000-0xf13fffff 64bit pref]
[    0.095380] pci 0000:00:1c.3: PCI bridge to [bus 04]
[    0.095390] pci 0000:00:1c.3:   bridge window [io  0xa000-0xafff]
[    0.095396] pci 0000:00:1c.3:   bridge window [mem 0xf5400000-0xf5dfffff]
[    0.095406] pci 0000:00:1c.3:   bridge window [mem 0xf0000000-0xf09fffff 64bit pref]
[    0.095574] pci 0000:05:00.0: [8086:10d3] type 00 class 0x020000
[    0.095724] pci 0000:05:00.0: reg 0x10: [mem 0xf7c00000-0xf7c1ffff]
[    0.095777] pci 0000:05:00.0: reg 0x18: [io  0x9000-0x901f]
[    0.095807] pci 0000:05:00.0: reg 0x1c: [mem 0xf7c20000-0xf7c23fff]
[    0.096022] pci 0000:05:00.0: PME# supported from D0 D3hot
[    0.096094] pci 0000:05:00.0: System wakeup disabled by ACPI
[    0.097715] pci 0000:00:1c.4: PCI bridge to [bus 05]
[    0.097725] pci 0000:00:1c.4:   bridge window [io  0x9000-0x9fff]
[    0.097730] pci 0000:00:1c.4:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.097836] pci 0000:06:00.0: [104c:8240] type 01 class 0x060400
[    0.098053] pci 0000:06:00.0: supports D1 D2
[    0.098100] pci 0000:06:00.0: System wakeup disabled by ACPI
[    0.099725] pci 0000:00:1c.6: PCI bridge to [bus 06-07]
[    0.099929] pci 0000:06:00.0: PCI bridge to [bus 07]
[    0.100756] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.100831] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.100905] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 10 11 12 14 15)
[    0.100974] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.101042] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 10 11 12 14 15)
[    0.101110] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.101183] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.101251] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.101762] ACPI: Enabled 4 GPEs in block 00 to 3F
[    0.101927] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.101935] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.101946] vgaarb: loaded
[    0.101951] vgaarb: bridge control possible 0000:00:02.0
[    0.102069] SCSI subsystem initialized
[    0.102706] libata version 3.00 loaded.
[    0.102748] ACPI: bus type USB registered
[    0.102777] usbcore: registered new interface driver usbfs
[    0.102794] usbcore: registered new interface driver hub
[    0.102809] usbcore: registered new device driver usb
[    0.102842] pps_core: LinuxPPS API ver. 1 registered
[    0.102848] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.102861] PTP clock support registered
[    0.103799] PCI: Using ACPI for IRQ routing
[    0.105554] PCI: pci_cache_line_size set to 64 bytes
[    0.105715] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.105718] e820: reserve RAM buffer [mem 0x40004000-0x43ffffff]
[    0.105720] e820: reserve RAM buffer [mem 0x77f84000-0x77ffffff]
[    0.105722] e820: reserve RAM buffer [mem 0x7877a000-0x7bffffff]
[    0.105724] e820: reserve RAM buffer [mem 0x78e02000-0x7bffffff]
[    0.105726] e820: reserve RAM buffer [mem 0x79000000-0x7bffffff]
[    0.105728] e820: reserve RAM buffer [mem 0x100600000-0x103ffffff]
[    0.105872] NetLabel: Initializing
[    0.105878] NetLabel:  domain hash size = 128
[    0.105883] NetLabel:  protocols = UNLABELED CIPSOv4
[    0.105902] NetLabel:  unlabeled traffic allowed by default
[    0.106105] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.106118] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.108200] clocksource: Switched to clocksource hpet
[    0.114522] pnp: PnP ACPI init
[    0.114667] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.114678] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.114800] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.114807] system 00:01: [io  0x1000-0x100f] has been reserved
[    0.114814] system 00:01: [io  0xffff] has been reserved
[    0.114821] system 00:01: [io  0xffff] has been reserved
[    0.114827] system 00:01: [io  0x0400-0x0453] could not be reserved
[    0.114834] system 00:01: [io  0x0458-0x047f] has been reserved
[    0.114840] system 00:01: [io  0x0500-0x057f] has been reserved
[    0.114846] system 00:01: [io  0x164e-0x164f] has been reserved
[    0.114854] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.114901] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.114981] system 00:03: [io  0x0454-0x0457] has been reserved
[    0.114990] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.115092] system 00:04: [io  0x0a00-0x0a01] has been reserved
[    0.115101] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.115399] pnp 00:05: [dma 0 disabled]
[    0.115488] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.115713] pnp 00:06: [dma 0 disabled]
[    0.115794] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.115876] system 00:07: [io  0x04d0-0x04d1] has been reserved
[    0.115885] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.116188] system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.116211] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.116219] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.116226] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.116233] system 00:08: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.116240] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.116247] system 00:08: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.116254] system 00:08: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.116261] system 00:08: [mem 0xff000000-0xffffffff] has been reserved
[    0.116268] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.116275] system 00:08: [mem 0x7da00000-0x7da00fff] has been reserved
[    0.116283] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.116490] system 00:09: [mem 0x20000000-0x201fffff] has been reserved
[    0.116498] system 00:09: [mem 0x40004000-0x40004fff] has been reserved
[    0.116506] system 00:09: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.116533] pnp: PnP ACPI: found 10 devices
[    0.124574] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.124681] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.124690] pci 0000:00:1c.0:   bridge window [io  0xd000-0xdfff]
[    0.124703] pci 0000:00:1c.0:   bridge window [mem 0xf7200000-0xf7bfffff]
[    0.124714] pci 0000:00:1c.0:   bridge window [mem 0xf1e00000-0xf27fffff 64bit pref]
[    0.124731] pci 0000:00:1c.1: PCI bridge to [bus 02]
[    0.124738] pci 0000:00:1c.1:   bridge window [io  0xc000-0xcfff]
[    0.124750] pci 0000:00:1c.1:   bridge window [mem 0xf6800000-0xf71fffff]
[    0.124760] pci 0000:00:1c.1:   bridge window [mem 0xf1400000-0xf1dfffff 64bit pref]
[    0.124776] pci 0000:00:1c.2: PCI bridge to [bus 03]
[    0.124784] pci 0000:00:1c.2:   bridge window [io  0xb000-0xbfff]
[    0.124795] pci 0000:00:1c.2:   bridge window [mem 0xf5e00000-0xf67fffff]
[    0.124806] pci 0000:00:1c.2:   bridge window [mem 0xf0a00000-0xf13fffff 64bit pref]
[    0.124822] pci 0000:00:1c.3: PCI bridge to [bus 04]
[    0.124829] pci 0000:00:1c.3:   bridge window [io  0xa000-0xafff]
[    0.124841] pci 0000:00:1c.3:   bridge window [mem 0xf5400000-0xf5dfffff]
[    0.124851] pci 0000:00:1c.3:   bridge window [mem 0xf0000000-0xf09fffff 64bit pref]
[    0.124868] pci 0000:00:1c.4: PCI bridge to [bus 05]
[    0.124876] pci 0000:00:1c.4:   bridge window [io  0x9000-0x9fff]
[    0.124886] pci 0000:00:1c.4:   bridge window [mem 0xf7c00000-0xf7cfffff]
[    0.124902] pci 0000:06:00.0: PCI bridge to [bus 07]
[    0.124930] pci 0000:00:1c.6: PCI bridge to [bus 06-07]
[    0.124950] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.124952] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.124955] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.124957] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[    0.124959] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[    0.124962] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[    0.124964] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[    0.124966] pci_bus 0000:00: resource 11 [mem 0x7da00000-0xfeafffff window]
[    0.124969] pci_bus 0000:01: resource 0 [io  0xd000-0xdfff]
[    0.124971] pci_bus 0000:01: resource 1 [mem 0xf7200000-0xf7bfffff]
[    0.124973] pci_bus 0000:01: resource 2 [mem 0xf1e00000-0xf27fffff 64bit pref]
[    0.124976] pci_bus 0000:02: resource 0 [io  0xc000-0xcfff]
[    0.124978] pci_bus 0000:02: resource 1 [mem 0xf6800000-0xf71fffff]
[    0.124980] pci_bus 0000:02: resource 2 [mem 0xf1400000-0xf1dfffff 64bit pref]
[    0.124982] pci_bus 0000:03: resource 0 [io  0xb000-0xbfff]
[    0.124984] pci_bus 0000:03: resource 1 [mem 0xf5e00000-0xf67fffff]
[    0.124987] pci_bus 0000:03: resource 2 [mem 0xf0a00000-0xf13fffff 64bit pref]
[    0.124989] pci_bus 0000:04: resource 0 [io  0xa000-0xafff]
[    0.124991] pci_bus 0000:04: resource 1 [mem 0xf5400000-0xf5dfffff]
[    0.124993] pci_bus 0000:04: resource 2 [mem 0xf0000000-0xf09fffff 64bit pref]
[    0.124995] pci_bus 0000:05: resource 0 [io  0x9000-0x9fff]
[    0.124997] pci_bus 0000:05: resource 1 [mem 0xf7c00000-0xf7cfffff]
[    0.125038] NET: Registered protocol family 2
[    0.125277] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    0.125334] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    0.125393] TCP: Hash tables configured (established 16384 bind 16384)
[    0.125422] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    0.125439] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    0.125493] NET: Registered protocol family 1
[    0.126606] RPC: Registered named UNIX socket transport module.
[    0.126612] RPC: Registered udp transport module.
[    0.126617] RPC: Registered tcp transport module.
[    0.126622] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.126639] pci 0000:00:02.0: Video device with shadowed ROM
[    0.158422] PCI: CLS mismatch (64 != 32), using 64 bytes
[    0.158498] DMAR: Host address width 36
[    0.158505] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.158518] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c0000020e60262 ecap f0101a
[    0.158527] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.158537] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap c9008020660262 ecap f0105a
[    0.158546] DMAR: RMRR base: 0x0000007821c000 end: 0x00000078238fff
[    0.158553] DMAR: RMRR base: 0x00000079800000 end: 0x0000007d9fffff
[    0.158567] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.158574] software IO TLB [mem 0x66200000-0x6a200000] (64MB) mapped at [ffff880066200000-ffff88006a1fffff]
[    0.158676] RAPL PMU detected, API unit is 2^-32 Joules, 3 fixed counters 163840 ms ovfl timer
[    0.158685] hw unit of domain pp0-core 2^-16 Joules
[    0.158690] hw unit of domain package 2^-16 Joules
[    0.158696] hw unit of domain pp1-gpu 2^-16 Joules
[    0.159067] Scanning for low memory corruption every 60 seconds
[    0.159456] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.159489] audit: initializing netlink subsys (disabled)
[    0.159503] audit: type=2000 audit(1489071862.156:1): initialized
[    0.161459] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.165034] VFS: Disk quotas dquot_6.6.0
[    0.165100] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.167330] NFS: Registering the id_resolver key type
[    0.167344] Key type id_resolver registered
[    0.167349] Key type id_legacy registered
[    0.167513] SELinux:  Registering netfilter hooks
[    0.168758] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.168772] io scheduler noop registered
[    0.168779] io scheduler deadline registered
[    0.168819] io scheduler cfq registered (default)
[    0.169939] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.169967] efifb: probing for efifb
[    0.169990] efifb: framebuffer at 0xe0000000, mapped to 0xffffc90000400000, using 3072k, total 3072k
[    0.169999] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    0.170005] efifb: scrolling: redraw
[    0.170010] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.172789] Console: switching to colour frame buffer device 128x48
[    0.175107] fb0: EFI VGA frame buffer device
[    0.175331] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    0.175380] ACPI: Sleep Button [SLPB]
[    0.175462] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input1
[    0.175522] ACPI: Lid Switch [LIDB]
[    0.175602] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[    0.175648] ACPI: Power Button [PWRB]
[    0.175727] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    0.175769] ACPI: Power Button [PWRF]
[    0.176476] Monitor-Mwait will be used to enter C-1 state
[    0.178478] thermal LNXTHERM:00: registered as thermal_zone0
[    0.178513] ACPI: Thermal Zone [TZ00] (28 C)
[    0.178804] thermal LNXTHERM:01: registered as thermal_zone1
[    0.178837] ACPI: Thermal Zone [TZ01] (30 C)
[    0.178992] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.199784] 00:05: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    0.220534] 00:06: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[    0.220890] serial 0000:00:16.3: enabling device (0000 -> 0003)
[    0.241620] 0000:00:16.3: ttyS2 at I/O 0xe140 (irq = 19, base_baud = 115200) is a 16550A
[    0.243082] Non-volatile memory driver v1.3
[    0.244328] Linux agpgart interface v0.103
[    0.245605] [drm] Initialized drm 1.1.0 20060810
[    0.247683] [drm] Memory usable by graphics device = 2048M
[    0.248936] checking generic (e0000000 300000) vs hw (e0000000 10000000)
[    0.248938] fb: switching to inteldrmfb from EFI VGA
[    0.250111] Console: switching to colour dummy device 80x25
[    0.250261] [drm] Replacing VGA console driver
[    0.250714] kworker/u4:0 (866) used greatest stack depth: 13544 bytes left
[    0.256375] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    0.256382] [drm] Driver supports precise vblank timestamp query.
[    0.256777] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    0.265501] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    0.265742] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4
[    0.265776] [drm] Initialized i915 1.6.0 20151010 for 0000:00:02.0 on minor 0
[    0.275762] loop: module loaded
[    0.275843] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20150930/utaddress-254)
[    0.275862] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    0.275874] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150930/utaddress-254)
[    0.275891] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    0.275900] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150930/utaddress-254)
[    0.275916] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    0.275925] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20150930/utaddress-254)
[    0.275940] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000503 (\_SB_.PCI0.LPCB.ADSM) (20150930/utaddress-254)
[    0.275956] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    0.275965] lpc_ich: Resource conflict(s) found affecting gpio_ich
[    0.276097] ata_piix 0000:00:1f.2: version 2.13
[    0.276244] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    0.374669] fbcon: inteldrmfb (fb0) is primary device
[    0.428822] scsi host0: ata_piix
[    0.429985] scsi host1: ata_piix
[    0.430051] ata1: SATA max UDMA/133 cmd 0xe130 ctl 0xe120 bmdma 0xe0f0 irq 19
[    0.430056] ata2: SATA max UDMA/133 cmd 0xe110 ctl 0xe100 bmdma 0xe0f8 irq 19
[    0.430180] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[    0.523448] [drm:intel_set_pch_fifo_underrun_reporting] *ERROR* uncleared pch fifo underrun on pch transcoder A
[    0.523450] [drm:intel_pch_fifo_underrun_irq_handler] *ERROR* PCH transcoder A FIFO underrun
[    0.554953] Console: switching to colour frame buffer device 128x48
[    0.557694] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    0.580245] ata_piix 0000:00:1f.5: SCR access via SIDPR is available but doesn't work
[    0.581731] scsi host2: ata_piix
[    0.582909] scsi host3: ata_piix
[    0.582995] ata3: SATA max UDMA/133 cmd 0xe0d0 ctl 0xe0c0 bmdma 0xe090 irq 19
[    0.583035] ata4: SATA max UDMA/133 cmd 0xe0b0 ctl 0xe0a0 bmdma 0xe098 irq 19
[    0.583142] CAN device driver interface
[    0.583167] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[    0.583200] e100: Copyright(c) 1999-2006 Intel Corporation
[    0.583259] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[    0.584571] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    0.585892] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    0.587371] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    0.588825] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    0.830533] e1000e 0000:00:19.0 eth0: registered PHC clock
[    0.831819] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 00:30:64:17:a5:4a
[    0.833130] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[    0.834462] e1000e 0000:00:19.0 eth0: MAC: 10, PHY: 11, PBA No: FFFFFF-0FF
[    0.835748] e1000e 0000:05:00.0: Disabling ASPM
[    0.836980] e1000e 0000:05:00.0: can't disable ASPM; OS doesn't have ASPM control
[    0.838244] e1000e 0000:05:00.0: enabling device (0000 -> 0002)
[    0.839684] e1000e 0000:05:00.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    0.841165] e1000e: probe of 0000:05:00.0 failed with error -2
[    0.842432] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[    0.843665] igb: Copyright (c) 2007-2014 Intel Corporation.
[    0.845023] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.846246] ehci-pci: EHCI PCI platform driver
[    0.847643] ehci-pci 0000:00:1a.0: EHCI Host Controller
[    0.848914] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1
[    0.850136] ehci-pci 0000:00:1a.0: debug port 2
[    0.855229] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[    0.855243] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7d27000
[    0.862232] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    0.863425] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.864578] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.865730] usb usb1: Product: EHCI Host Controller
[    0.866873] usb usb1: Manufacturer: Linux 4.4.12-rt19+ ehci_hcd
[    0.868037] usb usb1: SerialNumber: 0000:00:1a.0
[    0.869353] hub 1-0:1.0: USB hub found
[    0.870524] hub 1-0:1.0: 2 ports detected
[    0.871952] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.873148] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    0.874294] ehci-pci 0000:00:1d.0: debug port 2
[    0.879295] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[    0.879309] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7d26000
[    0.886234] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.887341] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    0.888409] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.889491] usb usb2: Product: EHCI Host Controller
[    0.890557] usb usb2: Manufacturer: Linux 4.4.12-rt19+ ehci_hcd
[    0.891637] usb usb2: SerialNumber: 0000:00:1d.0
[    0.892856] hub 2-0:1.0: USB hub found
[    0.893924] hub 2-0:1.0: 2 ports detected
[    0.895136] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.896200] ohci-pci: OHCI PCI platform driver
[    0.897312] uhci_hcd: USB Universal Host Controller Interface driver
[    0.898455] usbcore: registered new interface driver usblp
[    0.899557] usbcore: registered new interface driver usb-storage
[    0.900702] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    1.418600] tsc: Refined TSC clocksource calibration: 2195.013 MHz
[    1.419641] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fa3cbf1da7, max_idle_ns: 440795275681 ns
[    1.938824] i8042: No controller found
[    1.939974] mousedev: PS/2 mouse device common for all mice
[    1.941437] rtc_cmos 00:02: RTC can wake from S4
[    1.942691] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[    1.943816] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    1.945059] ACPI Warning: SystemIO range 0x000000000000E040-0x000000000000E05F conflicts with OpRegion 0x000000000000E040-0x000000000000E04F (\_SB_.PCI0.SBUS.SMBI) (20150930/utaddress-254)
[    1.947404] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[    1.948707] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    1.949886] EFI Variables Facility v0.08 2004-May-17
[    1.960389] hidraw: raw HID events driver (C) Jiri Kosina
[    1.962206] usbcore: registered new interface driver usbhid
[    1.963465] usbhid: USB HID core driver
[    1.964954] Netfilter messages via NETLINK v0.30.
[    1.966154] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.967498] ctnetlink v0.93: registering with nfnetlink.
[    1.968841] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.970103] Initializing XFRM netlink socket
[    1.971567] NET: Registered protocol family 10
[    1.973001] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    1.974370] sit: IPv6 over IPv4 tunneling driver
[    1.975779] NET: Registered protocol family 17
[    1.976955] can: controller area network core (rev 20120528 abi 9)
[    1.978173] NET: Registered protocol family 29
[    1.979388] can: raw protocol (rev 20120528)
[    1.980579] can: broadcast manager protocol (rev 20120528 t)
[    1.981782] can: netlink gateway (rev 20130117) max_hops=1
[    1.983060] Key type dns_resolver registered
[    1.984520] microcode: CPU0 sig=0x306a9, pf=0x10, revision=0x17
[    1.985729] microcode: CPU1 sig=0x306a9, pf=0x10, revision=0x17
[    1.986949] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.989075] registered taskstats version 1
[    1.991814]   Magic number: 9:759:82
[    1.993031] event_source uncore_cbox_0: hash matches
[    1.994295] console [netcon0] enabled
[    1.995505] netconsole: network logging started
[    1.996811] PM: Hibernation image not present or could not be loaded.
[    2.039250] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    2.040478] usb 2-1: new high-speed USB device number 2 using ehci-pci
[    2.088337] ata1.00: SATA link down (SStatus 0 SControl 330)
[    2.089541] ata1.01: SATA link up 1.5 Gbps (SStatus 113 SControl 330)
[    2.105485] ata1.01: ATA-8: 8GB NANDrive, D A411G2, max UDMA/133
[    2.106660] ata1.01: 15649200 sectors, multi 0: LBA48
[    2.110480] ata1.01: configured for UDMA/133
[    2.123413] scsi 0:0:1:0: Direct-Access     ATA      8GB NANDrive     11G2 PQ: 0 ANSI: 5
[    2.124813] sd 0:0:1:0: [sda] 15649200 512-byte logical blocks: (8.01 GB/7.46 GiB)
[    2.126050] sd 0:0:1:0: [sda] Write Protect is off
[    2.127197] sd 0:0:1:0: [sda] Mode Sense: 00 3a 00 00
[    2.127217] sd 0:0:1:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    2.128455] sd 0:0:1:0: Attached scsi generic sg0 type 0
[    2.130619]  sda: sda1
[    2.131970] sd 0:0:1:0: [sda] Attached SCSI disk
[    2.165595] usb 1-1: New USB device found, idVendor=8087, idProduct=0024
[    2.166685] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.167795] usb 2-1: New USB device found, idVendor=8087, idProduct=0024
[    2.168849] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.170146] hub 2-1:1.0: USB hub found
[    2.171238] hub 1-1:1.0: USB hub found
[    2.172306] hub 2-1:1.0: 8 ports detected
[    2.173332] hub 1-1:1.0: 6 ports detected
[    2.420324] clocksource: Switched to clocksource tsc
[    2.448253] usb 1-1.1: new high-speed USB device number 3 using ehci-pci
[    2.450251] usb 2-1.3: new low-speed USB device number 3 using ehci-pci
[    2.532466] usb 2-1.3: New USB device found, idVendor=1a2c, idProduct=0e24
[    2.533507] usb 2-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.534536] usb 2-1.3: Product: USB Keyboard
[    2.535565] usb 2-1.3: Manufacturer: SEM
[    2.538717] usb 1-1.1: New USB device found, idVendor=090c, idProduct=1000
[    2.539751] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.540779] ata2.01: failed to resume link (SControl 30)
[    2.553511] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.0/0003:1A2C:0E24.0001/input/input5
[    2.555678] usb 1-1.1: Product: Silicon-Power
[    2.556764] usb 1-1.1: Manufacturer: UFD 2.0
[    2.557837] usb 1-1.1: SerialNumber: 1400873704326177
[    2.559037] ata2.00: SATA link down (SStatus 0 SControl 330)
[    2.560137] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[    2.561250] ata2.01: SATA link down (SStatus 4 SControl 30)
[    2.563425] scsi host4: usb-storage 1-1.1:1.0
[    2.573287] md: Waiting for all devices to be available before autodetect
[    2.574369] md: If you don't use raid, use raid=noautodetect
[    2.607456] hid-generic 0003:1A2C:0E24.0001: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-0000:00:1d.0-1.3/input0
[    2.613343] input: SEM USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.3/2-1.3:1.1/0003:1A2C:0E24.0002/input/input6
[    2.666351] hid-generic 0003:1A2C:0E24.0002: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-0000:00:1d.0-1.3/input1
[    2.670130] md: Autodetecting RAID arrays.
[    2.671389] md: Scanned 0 and added 0 devices.
[    2.672649] md: autorun ...
[    2.673877] md: ... autorun DONE.
[    2.675093] Waiting for root device /dev/sdb2...
[    3.994012] scsi 4:0:0:0: Direct-Access     UFD 2.0  Silicon-Power8G  1100 PQ: 0 ANSI: 4
[    3.995428] sd 4:0:0:0: Attached scsi generic sg1 type 0
[    3.997255] sd 4:0:0:0: [sdb] 15730688 512-byte logical blocks: (8.05 GB/7.50 GiB)
[    3.999398] sd 4:0:0:0: [sdb] Write Protect is off
[    4.000631] sd 4:0:0:0: [sdb] Mode Sense: 43 00 00 00
[    4.001617] sd 4:0:0:0: [sdb] No Caching mode page found
[    4.002871] sd 4:0:0:0: [sdb] Assuming drive cache: write through
[    4.008509]  sdb: sdb1 sdb2
[    4.012492] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[    4.091649] EXT4-fs (sdb2): couldn't mount as ext3 due to feature incompatibilities
[    4.094007] EXT4-fs (sdb2): couldn't mount as ext2 due to feature incompatibilities
[    4.107406] EXT4-fs (sdb2): INFO: recovery required on readonly filesystem
[    4.108681] EXT4-fs (sdb2): write access will be enabled during recovery
[    4.148890] EXT4-fs (sdb2): recovery complete
[    4.157258] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
[    4.158542] VFS: Mounted root (ext4 filesystem) readonly on device 8:18.
[    4.163517] devtmpfs: mounted
[    4.166128] Freeing unused kernel memory: 1024K (ffffffff81d00000 - ffffffff81e00000)
[    4.167429] Write protecting the kernel read-only data: 12288k
[    4.168947] Freeing unused kernel memory: 188K (ffff8800017d1000 - ffff880001800000)
[    4.174497] Freeing unused kernel memory: 1508K (ffff880001a87000 - ffff880001c00000)
[    4.377266] EXT4-fs (sdb2): re-mounted. Opts: errors=remount-ro,data=ordered
[    4.397998] hostname (1194) used greatest stack depth: 13408 bytes left
[    4.605638] random: nonblocking pool is initialized
[    4.619990] udevd[1204]: starting version 3.2
[    4.674627] udevd (1204) used greatest stack depth: 13216 bytes left
[    4.676143] udevd[1205]: starting eudev-3.2
[    4.717054] udevadm (1206) used greatest stack depth: 12904 bytes left
[    4.772171] e1000e 0000:00:19.0 eno1: renamed from eth0
[    5.066141] rcS (1195) used greatest stack depth: 12696 bytes left
George Kang
Reason: Inserted Code tag for better readability
S.Grosjean
Post by S.Grosjean » Fri 10. Mar 2017, 10:35
Several things about your post:
  • you're actually running a PREEMPT_RT version of Linux (Linux version 4.4.12-rt19+), not a standard version.
  • you shouldn't have to "ip link add" the can interfaces by hand but these should be automatically registered when booting.
  • Finally, it looks like the linux-can base modules are loaded but neither are the SJA1000 (sja000.ko) nor the PEAK-System (peak_pci.ko) modules
When running a Linux system, the can devices are automatically created when booting, because the System loads the corresponding modules while enumerating the hardware.
So it looks like your board is not detected by the System.
Could you please type:
$ lspci -d 001C:
Moreover, instead of using the "ip link add" command, please try:
$ sudo modprobe sja1000
$ sudo modprobe peak_pci
Then, type:
$ ip link show type can
Stéphane
— Stéphane
O.Hartkopp
Post by O.Hartkopp » Thu 23. Mar 2017, 18:53
S.Grosjean wrote:Hi,
In fact the 4.4.12 (released 2016-06-01) did not follow recent patches applied to the Linux 4.4.y stable tree.
See the patches for CAN drivers in Linux 4.4.y:
https://git.kernel.org/pub/scm/linux/ke ... inux-4.4.y
You need to apply this patch to fix the issue in 4.4.12:
https://git.kernel.org/pub/scm/linux/ke ... 3fb3a2d2de
Oliver
