MicroMod Mix2 Temperatuer sensor range
mdenton
Post by mdenton » Tue 28. Sep 2010, 22:28
Is there a way to extend either of the temperature sensor ranges above 70 degrees on the MicroMod Mix2 module?
Matt Denton
Micromagic Systems - www.micromagicsystems.com
Hexapod Robot - www.hexapodrobot.com
mdenton
Re: MicroMod Mix2 Temperatuer sensor range
Post by mdenton » Wed 29. Sep 2010, 08:39
Another thought is would it be possible to convert the PT1000 input to work with a PT100 sensor?
Matt Denton
Post by G.Lang » Wed 29. Sep 2010, 11:37
Hi Matt,
it is possible to extend the temperature range from the NTC input. But for that we must know the new temperature range and you must change some SMD components on the pcb (note: you loose the warranty).
It is not possible (and not useful) to modify the PT1000 input to work with a PT100 sensor, sorry
