Command line options
ganesh.28
Post by ganesh.28 » Mon 12. Dec 2011, 14:47
I would like to perform following tasks from command line with PCAN view software. pls let me know the commands for the same:
1. Launch the PCAN-VIEW
2. Open the file.
3. Save the file
4. Exit from the PCAN- VIEW.
Also pls forward if any reference document available for this.
Re: Command line options
Post by M.Maidhof » Mon 12. Dec 2011, 16:39
PCAN-View does not offer a command line interface, only with PCAN-Explorer it will be possible to control the software by a VBscript, with which you can open and save files.
mynampatikuldeep
Post by mynampatikuldeep » Tue 10. Apr 2012, 01:38
I am using PCAN Explorer 5.0. I am currently using Standard Macros to send and receive CAN Messages. In order to automate, I would like to send and receive CAN messages and dump to a file using batch files commands or something similiar. Does PCAN Explorer 5.0 support this command line feature? If yes, can you direct me to appropriate support forum or documentation.
KK
Post by M.Maidhof » Tue 10. Apr 2012, 11:51
please have a look into the following directory: \Program Files\PCAN-Explorer 5\Samples\VBScript\
There you will find some samples on how to use vbs scripts.
When you open the help system in PCAN-Explorer 5, please have a look at "Automating Tasks in PCAN-Explorer", there are all information available about how to build up own scripts and macros.
BTW: perhaps this issue fits better into the PCAN-Explorer5 section of our forum.
