VB macro
Re: VB macro
Hi Piter,
yes, this will be possible with a VB macro or even with a simple standard macro.
Re: VB macro
I advised with trace but i don't how sent this information via CAN. If You can paste code I will very thankful.
Piter
Piter
Re: VB macro
Sorry, but I don't understand your last post. Which information do you mean?
Re: VB macro
I don't know how to use this code " Send 1 310h 8 04h 00h 00h 00h 00h 00h 00h 00h" in VB macro.
It's very simple in standard macro but under VB macro don't work.I try with "ExecuteCommand" but it's work only with "send" without any parameters.
I need send this message "310h 8 04h 00h 00h 00h 00h 00h 00h 00h" on bus 1 in the VB macro.
Re: VB macro
Please see the NewClientSend() macro in the macro list, which is a demo VB macro, showing you how to send out a CAN frame with VBmacro.
Re: VB macro
Hello Michael,
I'm back to this topic because I have problem with this example.
It's theoretical send message but in trace it's marked as RX message, not TX!!
When I'm sending for ex. ID100 manually from transmit/receive panel all is OK.
Do You have any suggestion?
Piter
I'm finded solution on Your forum
http://www.peak-system.com/forum/viewto ... rite#p1230
Piter
Re: VB macro
the VB macro creates a new client, this is like a new application besides PCAN-Explorer. That´s why PCAN-Explorer will receive that message as RX and not as TX.
