PCAN-USB Pro FD failed to transmit at baud below 1Mbit/s
cheeyw
Post by cheeyw » Mon 28. Aug 2017, 15:55
Setup Environment:
OS: Ubuntu 14.04 (64bit)
Driver: peak-linux-driver-8.4.0
I have used the test program that comes with the peak driver.
I have setup two running programs:
>>./receivetest -f=/dev/pcan33 -b=0x0014 -e
>>./transmitest -f=/dev/pcan32 –b=0x0014 -e hello.txt
hello.txt contains:
m e 0x1FFFFFFB 8 0x88 0x99 0xAa 0xbB 0xCc 0xdD 0xEe 0xfF
It is fine when both programs uses baud rate 1Mbit/s (-b=0x0014)
However if i tried to set the baud rate for both programs to be 500kbit/s (0x001C) or 250kbit/s (0x011C), the receivetest will not receive any messages, and the transmitest will have an error:
transmitest: CAN_Write(): Network is down
Please advice how to resolve this issue? Thanks!
S.Grosjean
Re: PCAN-USB Pro FD failed to transmit at baud below 1Mbit/s
Post by S.Grosjean » Mon 28. Aug 2017, 17:00
Can you redo your test but with the more recent test tool "pcanfdtst" please, that is:
Rx side:
% pcanfdtst rx -b 500k /dev/pcan33
Tx side:
$ pcanfdtst tx -b 500k -n 10 -ie 0x1FFFFFFB -I 8 /dev/pcan32
Can you also give us the output of:
$ cat /proc/pcan
Stéphane
— Stéphane
cheeyw
Post by cheeyw » Mon 28. Aug 2017, 17:59
Hello Stéphane,
It worked with the suggestions you gave.
BTW, does the pcanfdtst.c source codes able to work on other PCAN products (PCAN-USB, PCAN-PCI, PCAN-miniPCI, etc)? Or does it only work on PCAN-USB Pro FD?
Also which sample codes do you recommend for coding in c++ Linux that is supports PCAN-USB, PCAN-USB-FD and PCAN-PCI products?
cat /proc/pcan
*------------- Release_20170613_n (8.4.0) Aug 28 2017 15:05:03 --------------
*--------------------- 2 interfaces @ major 248 found -----------------------
32  usbfd   -NA- ffffffff 255 0x001c 00000001 00000064 00000065 00000000 0x0000
33  usbfd   -NA- ffffffff 255 0x001c 00000065 00000000 00000065 00000000 0x0000
S.Grosjean
Post by S.Grosjean » Tue 29. Aug 2017, 09:42
pcanfdtst is a more powerful and flexible tool than the two older ones. It is obviously compatible with all of our CAN devices, while the older ones are (for example) not CAN-FD capable (Both of these are kept for historical reason only. Anyway, we will have a look to the issue you have found with...).
We actually encourage new users to use the (new) libpcanfd library which is a super set if the old one libpcan. It is more efficient and offers very much more possibilities to user applications. That's the reason why I would strongly suggest you to get inspiration from pcanfdtst.c, regardless of which PEAK CAN product you want to use. Documentation folder contains a User Guide PDF that describes this API.
Stéphane
— Stéphane
