CAN Baud Rate 100K
gh.yu
CAN Baud Rate 100K
Post by gh.yu » Tue 29. Aug 2017, 02:39
I'm developing Serial to CAN using PCAN-RS232.
PCAN-RS232 with CAN baudrate 500K is working well.
But PCAN-RS232 with CAN baudrate 100K is not working.
Could you let me know the reason or some of check points?
Re: CAN Baud Rate 100K
Post by PEAK-Support » Tue 29. Aug 2017, 15:25
- Which Firmware do you use (own, or one of our samples)
- If you use our default sample firmware, read the PDF in the sample Directory - page 15.
There you find how to change the Baudrate of the CAN Channel via the RS232 command Sn[CR]
Please always send more information when you post a support request. We really try to do our best, but we cannot clairvoyance. :D
gh.yu
Post by gh.yu » Wed 30. Aug 2017, 04:10
Thank you for your guide.
Actually, I didn't find document you commented.
I have "PCAN-RS-232_UserMan_eng.pdf" and there is no description you mentioned at Page 15.
Could you please share the document you referred?
Post by PEAK-Support » Wed 30. Aug 2017, 10:07
Take a look in the directory of the Product DVD where the Sample code ist stored. There you will find all Info.
Develop\Microcontroller hardware\PCAN-RS-232\Examples\6_CAN_TO_SER_BY_COMMAND\help\
