2 or more symbol files
fabri_z
Post by fabri_z » Fri 13. Jan 2012, 14:10
i want to activate 2 or more symbol files for the receive / transmit window
is ti possible?
Fabrizio
Re: 2 or more symbol files
Post by PEAK-Support » Mon 16. Jan 2012, 09:32
In PE5 one connection could handle one Symbol File.
If you need a second Symbol file you could:
Merge Symbol File 1 and Symbol File 2 into one "big" Symbol File
or
You add a second Connection that use the same NET (same Hardware). Then you could add to the new connection a own Symbol file. (see attached picture)
More than one Symbol with one Hardware
