Line Writer
ESCHL
Line Writer
Post by ESCHL » Tue 17. Jan 2012, 13:41
Hi all,
how can I save my recorded graphics from the line writer window?
If I save the data as *.plw file and re-open it, the line writer window is empty except the configuration data. And is it possible to change the max. amount of records from 32000 to 64000 or above?
Thanks for your hints.
eschl
Re: Line Writer
Post by PEAK-Support » Tue 17. Jan 2012, 15:17
When you save a *.plw file, you always save the Values to the file.
Here a sample (the plw file is attached) please open in PE5.
PLW SInus
PLW SInus
The size of the Line writer is limited to 32000 Data points.
If you need more Data point, you could use the Plotter Add-In:
PCAN-Explorer Plotter Add-In
Please also check if you have the latest Version of the Software (Start page of PE5 - NEWS)
Sinus.plw
SinusPLWFile
(22.9 KiB) Downloaded 575 times
