unable to comm w/ device on ubuntu 16.04
andrewdisp
Post by andrewdisp » Wed 11. Oct 2017, 02:42
I'm trying to communicate w/ http://leddartech.com/modules/leddarvu/ on ubuntu 16.04 using http://www.peak-system.com/PCAN-USB-Pro ... .html?&L=1:
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 16.04.3 LTS
Release:	16.04
Codename:	xenial
$ uname -a
Linux ai-P65-P67RGRERA 4.4.0-040400-generic #201601101930 SMP Mon Jan 11 00:32:41 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
when i connect PCAN-USB Pro FD it is identified fine:
$ dmesg -wH
[  +4.148002] usb 1-1: new high-speed USB device number 36 using xhci_hcd
[  +0.128854] usb 1-1: config 1 interface 0 altsetting 0 bulk endpoint 0x83 has invalid maxpacket 64
[  +0.000008] usb 1-1: config 1 interface 1 altsetting 0 bulk endpoint 0x84 has invalid maxpacket 64
[  +0.000003] usb 1-1: config 1 interface 1 altsetting 0 bulk endpoint 0x4 has invalid maxpacket 64
[  +0.000004] usb 1-1: config 1 interface 1 altsetting 0 bulk endpoint 0x85 has invalid maxpacket 64
[  +0.000003] usb 1-1: config 1 interface 1 altsetting 0 bulk endpoint 0x5 has invalid maxpacket 64
[  +0.000003] usb 1-1: config 1 interface 1 altsetting 0 bulk endpoint 0x86 has invalid maxpacket 64
[  +0.000004] usb 1-1: config 1 interface 1 altsetting 0 bulk endpoint 0x6 has invalid maxpacket 64
[  +0.000422] usb 1-1: New USB device found, idVendor=0c72, idProduct=0011
[  +0.000006] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  +0.000004] usb 1-1: Product: PCAN-USB Pro FD
[  +0.000003] usb 1-1: Manufacturer: PEAK-System Technik GmbH
[  +0.006218] peak_usb 1-1:1.0: PEAK-System PCAN-USB Pro FD v2 fw v2.1.0 (2 channels)
[  +0.000214] peak_usb 1-1:1.0 can0: attached to PCAN-USB Pro FD channel 0 (device 4294967295)
[  +0.000267] peak_usb 1-1:1.0 can1: attached to PCAN-USB Pro FD channel 1 (device 4294967295)
[  +8.171873] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
and i can now create network interface for it:
$ sudo ip link set can0 up type can bitrate 500000
$ sudo ip link set up can0
but if i send a CAN frame to start streaming data from this device:
$ cansend can0 740#0300000000000000
i see this error:
$ candump can0,0:0,#FFFFFFFF -ace
  can0  740   [8]  03 00 00 00 00 00 00 00   '........'
  can0  20000004   [8]  00 08 00 00 00 00 00 00   ERRORFRAME
        controller-problem{tx-error-warning}
  can0  20000004   [8]  00 20 00 00 00 00 00 00   ERRORFRAME
        controller-problem{tx-error-passive}
and PCAN-USB Pro FD blinks red.
however keeping everything the same but using http://www.peak-system.com/PCAN-USB.199.0.html?L=1 instead communication works fine.
also if i plug same hardware configuration into windows and use PCAN-View to send frames communication works fine so i think i am not configuring the network interface correctly for PCAN-USB Pro FD:
Are there more settings i need to communicate w/ this non-FD CAN device?
Thanks for any help,
Andrew
S.Grosjean
Re: unable to comm w/ device on ubuntu 16.04
Post by S.Grosjean » Wed 11. Oct 2017, 11:21
Hello Andrew,
Due to higher clock frequencies, with CAN-FD equipment, you should use the "sample-point 0.xxx" option of "ip link set".
First, plug the PCAN-USB, do the setup of the can interface, then type:
$ ip -s -d link show can0
Note the "sample-point" value displayed, near to "bitrate xxx". Then, plug the CAN-FD equipment and setup the bitrate with the same sample-point.
For example, if the above command says:
bitrate 500000 sample-point 0.875
Then type:
$ ip link set can0 up type can bitrate 5000000 sample-point 0.875
Tip: you don't need to set the can0 interface up again, as you do...
Stéphane
— Stéphane
andrewdisp
Post by andrewdisp » Wed 11. Oct 2017, 19:39
Hello Stéphane,
Thanks for your help and work on the Linux driver.
I tried explicitly setting the sample-point but it does not seem to fix my error. If i create network interface w/o specifying sample-point i see e.g.:
82: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 10
    link/can  promiscuity 0
    can state ERROR-ACTIVE (berr-counter tx 0 rx 0) restart-ms 0
          tq 50 prop-seg 17 phase-seg1 17 phase-seg2 5 sjw 1
          pcan_usb_pro_fd: tseg1 1..64 tseg2 1..16 sjw 1..16 brp 1..1024 brp-inc 1
          pcan_usb_pro_fd: dtseg1 1..16 dtseg2 1..8 dsjw 1..4 dbrp 1..1024 dbrp-inc 1
          clock 80000000
          0          0          0          0          0          0
    RX: bytes  packets  errors  dropped overrun mcast
    0          0        0       0       0       0
    TX: bytes  packets  errors  dropped carrier collsns
    0
i then reconnect the adapter and this time specify sample-point 0.875 (i assume you meant bitrate 500000 not 5000000):
$ sudo ip link set can0 up type can bitrate 500000 sample-point 0.875
84: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 10
          clock 80000000
          0          0          0          0          0          0
    0          0        0       0       0       0
    0          0        0       0       0       0
which seems ~ same to me and candump reports comm error as before:
whenever i send can frame to start streaming from device:
again all works w/ non FD adapter (http://www.peak-system.com/PCAN-USB.199.0.html?L=1) so i think you are right that there is some FD comm related setting i need to use but i'm not sure which in addition to this sample-point.
Andrew
S.Grosjean
Post by S.Grosjean » Thu 12. Oct 2017, 11:05
Hello Andrew,
Please re-check your procedure:
I had asked to first read the sample-point from can0 when can0 corresponds to the PCAN-USB. According to your code, AFAIU you first had a look to the current sample-point of the PCAN-USB Pro FD. So your commands didn't change anything: you have setup the same sample-point value to the same device.
Stéphane
— Stéphane
andrewdisp
Post by andrewdisp » Thu 12. Oct 2017, 19:05
Hello Stéphane,
Sorry, I did that wrong. Here is what PCAN-USB says:
99: can0: <NOARP,UP,LOWER_UP,ECHO> mtu 16 qdisc pfifo_fast state UNKNOWN mode DEFAULT group default qlen 10
	  tq 125 prop-seg 6 phase-seg1 7 phase-seg2 2 sjw 1
	  clock 8000000
	  0          0          0          0          0          0
    0          0        0       0       0       0
    0          0        0       0       0       0
so it has sample-point 0.875. this is the same sample-point used by PCAN-USB FD from above.
Andrew
Post by M.Maidhof » Mon 16. Oct 2017, 10:52
please use a different clock setting for the 500k. Best solution is to use the same settings as under Windows with PCAN-View, using 24Mhz:
