I would like to identify PCAN adapters unambiguously.
Is there any way to get the serial number of PCAN adapter using PCANBasic?
I know devicenumber but it is not enough unique for me.
And what if I use canapi2.dll instead of PCANBasic?
David Fulop
Adaper identifying
Re: Adaper identifying
with the PCANBasic API you can set and check the devicenumber (1byte) of the PCAN-USB. With the canapi2.dll its also possible to set a serialnumber (32bit) and an "user string" with up to 250bytes. By default there is no serialnumber set in the PCAN-USB modules ( default: 0xFFFFFFFF). Setting those data will effect the life time of the flash memory of the device, so you shouldn't use it as an application memory
