I'm trying to use peak-linux-driver-8.4.0 on ubuntu 16.04. I did make, sudo make install, and sudo modprobe pcan, all without problem. However, receivetest and pcan-settings both gave me errors, as below:
$ receivetest -f=/dev/pcanusbfd32
receivetest Version "Release_20150611_n" (http://www.peak-system.com)
receivetest comes with ABSOLUTELY NO WARRANTY. This is free
software and you are welcome to redistribute it under certain
conditions. For details see attached COPYING file.
receivetest: device node="/dev/pcanusbfd32"
Only standard frames are accepted, init with 500 kbit/sec.
receivetest: can't open /dev/pcanusbfd32
receivetest: finished (71): 0 message(s) received
$ pcan-settings -f=/dev/pcanusbfd32 -s
pcan-settings: /dev/pcanusbfd32: Protocol error
$ dmesg | grep pcan
[ 5.904675] pcan: loading out-of-tree module taints kernel.
[ 5.904756] pcan: module verification failed: signature and/or required key missing - tainting kernel
[ 5.905248] pcan: Release_20170613_n
[ 5.905250] pcan: driver config [mod] [isa] [pci] [pec] [dng] [par] [usb] [pcc]
[ 5.907451] Modules linked in: pcan(OE+) snd_seq_midi snd_seq_midi_event pcmcia snd_rawmidi pcmcia_core i2c_algo_bit media snd_seq input_leds joydev snd_seq_device snd_timer serio_raw snd soundcore shpchp i2c_piix4 vmw_vmci nfit floppy(+) mac_hid binfmt_misc parport_pc ppdev lp parport autofs4 vmw_pvscsi vmxnet3 hid_generic usbhid hid psmouse vmwgfx ttm ahci e1000 libahci drm_kms_helper syscopyarea mptspi sysfillrect mptscsih sysimgblt fb_sys_fops mptbase drm scsi_transport_spi pata_acpi fjes
[ 5.907495] pcan_usbpro_request+0x62/0xb0 [pcan]
[ 5.907499] pcan_usbpro_driver_loaded+0x3f/0x60 [pcan]
[ 5.907502] pcan_usbfd_init+0x240/0xcf0 [pcan]
[ 5.907505] ? pcan_usb_plugin+0x4f5/0xa40 [pcan]
[ 5.907508] pcan_usb_plugin+0x52e/0xa40 [pcan]
[ 5.907510] ? pcan_usbfd_ctrl_init+0x80/0x80 [pcan]
[ 5.907524] ? pcan_soft_init_ex+0x320/0x320 [pcan]
[ 5.907527] pcan_usb_register_devices+0x5b/0x60 [pcan]
[ 5.907530] init_module+0x3c3/0x4b0 [pcan]
[ 5.907532] ? pcan_soft_init_ex+0x320/0x320 [pcan]
[ 5.908724] pcan: PCAN-USB FD (01h PCB01h) fw v2.3.1
[ 5.908911] pcan: unhandled read data stream turned off (err -71)
[ 5.909745] pcan: PCAN-USB FD channel 1 device number=0
[ 5.909746] pcan: usb device minor 32 found
[ 5.909762] usbcore: registered new interface driver pcan
[ 5.909770] pcan: major 244.
[ 42.044837] pcan: PCAN-USB FD (01h PCB01h) fw v2.3.1
[ 42.044951] pcan: unhandled read data stream turned off (err -71)
[ 42.045647] pcan: PCAN-USB FD channel 1 device number=0
[ 42.045745] pcan: usb device minor 32 found
Thank you,
-j
