Howto install the PEAK Linux driver on a fresh Ubuntu
Post by M.Maidhof » Tue 21. Feb 2012, 12:05
here is an info on howto install our peak-linux-driver-7.4 on a fresh installed Ubuntu 11.10 (same for 12.04, 12.10, 13.04, please use latest 7.x driver):
CHARDEV interface:
- download the driver peak-linux-driver-7.4.tar.gz from our linux website and copy it into your home directory.
- Install libpopt-dev: sudo apt-get install libpopt-dev
- Install g++: sudo apt-get install g++
(only necessary to build the test tool transmittest)
- unpack the driver: tar -xzf peak-linux-driver-7.4.tar.gz
- cd peak-linux-driver-7.4
- make clean
- make NET=NO
- sudo make install
- sudo modprobe pcan
- check with cat /proc/pcan that the driver was successfully installed.
*------------ PEAK-Systems CAN interfaces (http://www.peak-system.com) -------------
*-------------------------- Release_20110912_n (7.4.0) ----------------------
*---------------- [mod] [isa] [pci] [dng] [par] [usb] [pcc] -----------------
*--------------------- 1 interfaces @ major 250 found -----------------------
32 usb -NA- 30520000 255 0x001c 00000000 00000000 00000000 00000000 0x0000
now you can use the chardev tools in the /test directory or use cat /dev/pcan32 to see the messages in the console.
- to change the baudrate to 250k and enable extended IDs use:
echo "i 0x011C e" > /dev/pcan32
Re: Howto install the PEAK Linux driver on a fresh Ubuntu 11
Post by M.Maidhof » Wed 22. Feb 2012, 11:33
here now the same for the NetDev Interface:
NETDEV interface:
(only necessary to build the chardev test tool transmittest)
- make clean
- make
- sudo make install
32 usb can0 30520000 255 0x001c 00000000 00000000 00000000 00000000 0x0000
Now we are ready to install the SocketCAN Tools:
- goto home directory again:
cd
- Install git:
sudo apt-get install git
- Get the SocketCAN Tools:
git clone https://github.com/linux-can/can-utils
- build and install the tools:
cd can-utils
make
sudo make install
Set the network up:
sudo ifconfig can0 up
Test the communication with candump:
candump can0
-available tools are:
candump
cangen
cansend
canbusload
canecho
canlogserver
cansniffer
canfdtest
canplayer
to change the baudrate use the echo call, as written in the first post with chardev driver.
vagnusde67
Post by vagnusde67 » Fri 3. Aug 2012, 17:05
Hi Micheal, I compiled and installed usb pcan 7.7 running under ubuntu 12.04
This is the ouput of cat /proc/pcan
*-------------------------- Release_20120726_n (7.7.0) ----------------------
*------------- [dbg] [mod] [isa] [pci] [dng] [par] [usb] [pcc] --------------
*--------------------- 1 interfaces @ major 249 found -----------------------
32 usb -NA- ffffffff 255 0x001c 0000001c 00000034 0000007b 0000001c 0x0008
What puzzles me is the base address.
is it correct?
Post by M.Maidhof » Mon 6. Aug 2012, 13:53
yes this is correct, USB does not use a baseaddress or IRQ. So those two parameters are used to display SerNo and DeviceNumber of the USB device.
aljosa_fer
Post by aljosa_fer » Mon 3. Mar 2014, 21:17
*------------- Release_20130814_n (7.9.0) Mar 3 2014 21:07:51 --------------
*--------------------- 0 interfaces @ major 250 found -----------------------
is this ok why is 0 interfaces, maybe i dont have usb pcan connected ?
Post by PEAK-Support » Tue 4. Mar 2014, 09:13
when you do not have connected or plugged in a PEAK CAN card / adapter, the driver could not find one.
mccabehm
Post by mccabehm » Tue 1. Jul 2014, 22:23
Any complications when running Ubuntu 10.04 (Lucid, Linux version 2.6.32-38-generic) within VirtualBox? I always see "0 interfaces @ major 249 found" in /proc/pcan. The CAN/USB interface is physically attached. I have the USB device forwarded to the virtual machine. Using peak-linux-driver-7.11 as network device.
Harold
mccabehm
Post by mccabehm » Tue 1. Jul 2014, 23:55
I get around this problem when I run Ubuntu outside of VM. No further action required. Thanks,
Harold
Post by M.Maidhof » Wed 2. Jul 2014, 13:30
looks like a VM problem, please check that the VM extensions are installed on your VM client. But this issue is not related to our linux driver or hardware, it is a support issue of VirtualBox.
ikavoydo
Post by ikavoydo » Fri 7. Nov 2014, 18:19
Hi Michael,
I am using Peak CanUSB 2.0 for reading from a force sensor.
As I figured out, I have to connect to a socket can system.
When I was following your instruction, I see that I need to make the NETDEV interface, or?
When I do so, I get this:
*------------- Release_20140723_n (7.12.0) Oct 28 2014 19:47:08 --------------
32    usb -NA- ffffffff 255 0x001c 00000000 00000000 00000000 00000000 0x0000
As you see, the type of -ndev- is -NA-.
So when I continue with git clone for SocketCAN tools and do
of course it gives error, since there is no such a device called "can0"
Why am I getting
-NA-
for
-ndev-
and how can I fix it?
Thank you, and best,
Burak
