PCAN Driver Install on RPI
carllwyman
Post by carllwyman » Wed 25. Apr 2018, 20:56
I Have a PCAN USB , and I am trying to install the driver on the RPi, I have gone through older forums, but could not help me much. I am running 3.10.25+ I installed the linux headers for the same version, and installed libpopt as well. When i run make i get following output:
root@raspberrypi:/home/pi/Peak/peak-linux-driver-7.12# make clean
make[1]: Entering directory `/home/pi/Peak/peak-linux-driver-7.12/driver'
rm -f src/*o src/*~ src/.*cmd *o *ko *~ .*cmd pcan.mod.c
make[1]: Leaving directory `/home/pi/Peak/peak-linux-driver-7.12/driver'
make[1]: Entering directory `/home/pi/Peak/peak-linux-driver-7.12/lib'
rm -f src/*~ src/*.o *~ *.so.*
make[1]: Leaving directory `/home/pi/Peak/peak-linux-driver-7.12/lib'
make[1]: Entering directory `/home/pi/Peak/peak-linux-driver-7.12/test'
rm -f src/*~ src/*.o *~ receivetest transmitest bitratetest filtertest pcan-settings
make[1]: Leaving directory `/home/pi/Peak/peak-linux-driver-7.12/test'
root@raspberrypi:/home/pi/Peak/peak-linux-driver-7.12# make NET=NO PCI=NO PAR=NO ISA=NO PCC=NO DNG=NO
make[1]: *** No rule to make target `depend'. Stop.
*** Host machine kernel version=3.10.25+
*** Driver kernel version=3.10.25
*** Path to kernel sources=/lib/modules/3.10.25+/build
*** use KBUILD=yes
make -C /lib/modules/3.10.25+/build SUBDIRS=/home/pi/Peak/peak-linux-driver-7.12/driver EXTRA_CFLAGS="-I/home/pi/Peak/peak-linux-driver-7.12/driver -DNO_DEBUG -DMODVERSIONS -DNO -DUSB_SUPPORT -DNO -DNO_PCIEC_SUPPORT -DNO -DNO -DNO -DNO -DNO_RT " V=0 modules
make[2]: Entering directory `/usr/src/linux-headers-3.10.25+'
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_main.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_fops.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_fifo.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_filter.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_parse.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_sja1000.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_common.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_usb_core.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_usb.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_usbpro.o
CC [M] /home/pi/Peak/peak-linux-driver-7.12/driver/src/pcan_timing.o
LD [M] /home/pi/Peak/peak-linux-driver-7.12/driver/pcan.o
Building modules, stage 2.
MODPOST 1 modules
CC /home/pi/Peak/peak-linux-driver-7.12/driver/pcan.mod.o
LD [M] /home/pi/Peak/peak-linux-driver-7.12/driver/pcan.ko
make[2]: Leaving directory `/usr/src/linux-headers-3.10.25+'
# ln -sf ../driver/pcan.h pcan.h
cc src/libpcan.c -fPIC -shared -O2 -Wall -Wl,-soname,libpcan.so.0 -lc -I. -I../driver -DNO_RT -o libpcan.so.0.6
cc src/receivetest.c src/common.c -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o receivetest -lpcan -DNO_RT
cc src/transmitest.cpp src/common.c src/parser.cpp -I. -I../lib -I../driver -L../lib -L/lib -L/usr/lib -L/usr/local/lib -o transmitest -lpcan -lstdc++ -DNO_RT
cc: error trying to exec 'cc1plus': execvp: No such file or directory
make[1]: *** [transmitest] Error 1
I have updated and upgraded (sudo apt-get update/upgrade) I have updgraded both g++ and gcc but does not seem to have resolved the issue. Could you tell me from your experience how i can fix this? Thanks.
Also i wanted to ask, that In the USER MANUAL its written that in new kernel socketCAN support is already there and we do not need to install the driver. Does it mean that in case the SOCKETCAN config in the kernel is enabled, the driver does not need to be installed?
Reason: Added [code] tag to improve readability
nypdmax
Re: PCAN Driver Install on RPI
Post by nypdmax » Thu 26. Apr 2018, 08:01
1.
You're trying to compile cpp with gcc, could you show the output of the following command in your rpi
env
g++ --version
gcc --version
2. SocketCAN is supported ever from Linux 2.6. Run:
sudo modprobe configs
gunzip -c /proc/config.gz > ~/kernel.config
grep 'CAN' ~/kernel.config
and check the output for details.
Kernel has a driver for PCAN adpters but it's most likely your rpi doesn't include that module, so you have to manually compile it.
Post by M.Maidhof » Thu 26. Apr 2018, 13:43
Hi carllwyman,
looks like you are using an older Raspian image with kernel 3.10. You also use an older peak-linux-driver 7.12 on that system.
I would suggest to use the latest peak-linux-driver-8.5.1 and also update to a newer image with kernel 4.x.
This should solve your problem, because my RPI3 is running with that configuration without problems
