I have LEDs connected to signals that come from specific PGNs. When I stop receiving the PGNs the LEDs stay lit. Pressing the "reset" icon to reset the recieve history doesn't turn off the LEDs.
Is there a setting I should be using to timeout the signals or something similar? Or is this normal behavior of the software?
Thank you
Mike
Panel LEDs stay lit
Re: Panel LEDs stay lit
The LED use the last valid signal value. Simple define a"time out value" - so that the signal itslef set to this value if the CAN Frame does not update the signal in time.
I'm using version 5.1.2 where do I define "time out value"
Please Update to the latest Version (5.4.2) the used version 5.1.2 is from 2010 !! and definitly not up to date!
Send us you serial number per E-Mail to suppert[at]peak-system.com we will send you the download link.
