Panel LEDs stay lit
Posted: Mon 21. May 2018, 11:22
by mikeelece
I have LEDs connected to signals that come from specific PGNs. When I stop receiving the PGNs the LEDs stay lit. Pressing the "reset" icon to reset the recieve history doesn't turn off the LEDs.
Is there a setting I should be using to timeout the signals or something similar? Or is this normal behavior of the software?
Thank you
Mike
Re: Panel LEDs stay lit
Posted: Mon 4. Jun 2018, 16:54
The LED use the last valid signal value. Simple define a"time out value" - so that the signal itslef set to this value if the CAN Frame does not update the signal in time.
Posted: Wed 1. Aug 2018, 09:53
by mikeelece
I'm using version 5.1.2 where do I define "time out value"
Posted: Wed 1. Aug 2018, 10:36
Please Update to the latest Version (5.4.2) the used version 5.1.2 is from 2010 !! and definitly not up to date!
Send us you serial number per E-Mail to suppert[at]peak-system.com we will send you the download link.
