Event Based Messaging
gparks
Post by gparks » Wed 25. Jul 2018, 19:39
I am unsure how exactly the format of event based messaging works in the PPCAN editor, as there is no documentation on it in the user guide. I have attached the screenshot of the options available. My question is how this works? If I have Bus0 and some symbol that contains data, is the event type portion considering the symbol the "signal"? Or is that checking the I/O function? For this example I have made FFh I/O No 255 a ramp counter from 0 to 10, however I am not sure what this even does if it detects the proper event. Does it send the message specified, Symbol2 on bus0?
S.Schott
Hardware Development
Re: Event Based Messaging
Post by S.Schott » Thu 26. Jul 2018, 10:17
Hello.
That variable #255 must also be a signal in TX message bus0/symbol2.
Each time the variable #255 differs from the last sent signal
by <threshold> units, that message is assembled and sent with current values.
If still in doubt, please email your config file to:
info (at) peak-system.com
