Help to decode PCANView trace for Comm Stoppages
DougPLC
Post by DougPLC » Thu 23. Aug 2018, 16:55
I have almost no experience with CAN but have used PCANView 3.2 at someone else's direction.
Now my issue is on a different assembly machine using a Siemens S7-315 with ProfiBus to CAN bridge. The machine I/O is on CAN but we see a momentary communications freeze at random intervals - could be 15 secs to 3 minutes between freezes.
Can anyone help decode the attached trace file to help find the source of the error?
Also I see RTRs with ID 070A with no response. Is this a problem?
Any help would be appreciated.
T052 trace 0822 1733 shortened.trc
(4.72 MiB) Downloaded 628 times
Re: Help to decode PCANView trace for Comm Stoppages
Post by M.Maidhof » Fri 24. Aug 2018, 09:29
it will be better to post the problem in a Siemens PLC forum, we don´t know that system and in the trace we don`t see any CAN errors.
DougPLC
Post by DougPLC » Mon 10. Sep 2018, 12:59
Thanks for the recommendation but the folks on the Siemens forum don’t know anything about CAN bus.
How would electrical noise on the CAN bus show in a PCAN View trace?
If a station on the bus does not respond to an RTR what does that do to the performance of the bus?
Post by M.Maidhof » Mon 10. Sep 2018, 13:35
EMC could produce errorframes. You will see them as errors in the trace, when you have enabled this option in the tracer.
About RTR: this is depending on how the software protocol on that bus handles such an problem. By default, nothing will happen.
