Easiest Way To Send and Record TRC Files Under Linux?
I'm looking to play prerecorded PCAN TRC files back to a CAN device under Linux. I would also like to be able to record CAN messages in the TRC format. Is there an API or other similar thing that could help me do this?
Re: Easiest Way To Send and Record TRC Files Under Linux?
Warning: Please don't post the same question/issue several times in different topics. This will definitely don't accelare the support process and may be recognized as spam and be deleted, as well as the user account.
Recording: The PCAN-Basic API (both, Windows and Linux versions) allows you to automatically record CAN communication in PEAK Trace format (*.trc). The generated file is then compatible with all PEAK software supporting tracing, like PCAN-Explorer, PCAN-View, PCAN-Trace, etc. This functionality is activated over parameter through the function CAN_SetValue. Check the PCAN-Basic documentation for "Types/TPCANParameter/PCAN_TRACE_*" parameters.
Playback: Parsing and sending Trace files can be achieved in Windows, using PCAN-Explorer 6 and PCAN-Trace. There is no API that allows you to do this.
