Hallo ,
i would like to ask, if i can open an Instrument Panel by click one button in other Instrument Panel ?
i see in the "PCAN-Explorer-Befehle Liste ", there is a command " FileOpen", can i use it to solve my problem, or i should use a macro script. Can you give me an Example for this case?
thank you
switch between two different Instrument Panel
Re: switch between two different Instrument Panel
Please take a look in the Panel Online Docu. There you will see that there is a Z-Order Option for the Panel available.
In the Panel Properties you could select a "Scene switching Signal" With this Otion you could change the Scene of a Panel - which is like close a Panel and open a new one.
For more Information, please contact our support ( support[at]peak-system.com ) and add your serial number and company name to the E-Mail. Then we could send you some more information / samples.
