some question about PassThru and CANFD
uaes_hhl
Post by uaes_hhl » Mon 15. Oct 2018, 08:10
Can I use the PassThru API to enable the canfd transmission function of PCAN-USB FD?
Re: some question about PassThru and CANFD
Post by PEAK-Support » Mon 15. Oct 2018, 09:10
The FD Version of PassThru is not officially finished . So we have no final release for it.
(no ISO norm ready – no Release ready)
But we have buil, based on the GM Extension GMW177753, a PassThru Version that also Support CAN-FD.
Please contact our support if you are interested in a pre-release version of this API
uaes_hhl
Post by uaes_hhl » Wed 17. Oct 2018, 02:51
So now I want to use the canfd transmission function of pcan-usbfd, am I only use the Can basic api?
Reason: Removed full quote of preceding post
Post by K.Wagner » Wed 17. Oct 2018, 08:34
PCAN-Basic: Supports CAN and CAN-FD protocols
PCAN-ISO-TP: Supports ISO-15765-2, a.k.a. ISO-TP, and uses CAN and CAN-FD as transport protocol.
PCAN-UDS: Supports ISO-15765-3/ISO-14229, a.k.a. UDS, and uses CAN as transport protocol.
PCAN-OBDII: Supports ISO-15765-4, a.k.a. OBDII, and uses CAN as transport protocol.
PCAN-PassThru: Suppors CAN, ISO-15765-2, and ISO-15765-4, and uses CAN as transport protocol.
PCAN-PassThru (GMW177753)-BETA: Supports CAN, ISO-15765-2, ISO-15765-4, using CAN as transport protocol; and the proprietary protocol GMW-177753 (ISO-15765-2, ISO-14229) using CAN-FD as transport protocol.
uaes_hhl
Post by uaes_hhl » Tue 23. Oct 2018, 04:51
Thank you very much for your reply. I've got the DLL file, but where do I go to get the header file corresponding to the passthru API?
Post by K.Wagner » Tue 23. Oct 2018, 09:00
The PCAN-PassThru Api is actually thought to be used with applications that already implements J2534, so no header file is shipped. If you want to write your own J2534, you should acquire the documentation from SAE-J2534.
If you want to test the BETA-Version, that supports CAN-FD, you will need the GM documentation, GMW17753
Within the PDF shipped with PCAN-PassThru you find examples of use for each function API, with remarks on PEAK related data.
uaes_hhl
Post by uaes_hhl » Tue 20. Nov 2018, 06:58
PassThruIoctl always returns the error of "A PCAN Channel has not been initialized yet or the initialization process" when using passthru API to initialize canfd (ISO15765_FD_PS). However, if the option J1962_PINS is set, it will not retrun error, but I don't think I need to set this option. Is there any solution, or can you give a sample code to initialize canfd (ISO15765_FD_PS)?
Here is my code.
void CfgFDDevice15765(SCONFIG * CfgItem, SCONFIG_LIST & Input, unsigned int BS_15765, unsigned int STMIN_15765)
	CfgItem[0].Parameter = BS_TX;
	CfgItem[0].Value = BS_15765;
	//CfgItem[0].Value = 0xffff;
	CfgItem[1].Parameter = STMIN_TX;
	CfgItem[1].Value = STMIN_15765;
	//CfgItem[1].Value = 0xffff;
	CfgItem[2].Parameter = ISO15765_BS;
	CfgItem[2].Value = 0;
	CfgItem[3].Parameter = ISO15765_STMIN;
	CfgItem[3].Value = 0;
	//CfgItem[4].Parameter = J1962_PINS ;
	//CfgItem[4].Value = PIN6_14;
	Input.NumOfParams = 4;
	Input.ConfigPtr = &(CfgItem[0]);
Post by K.Wagner » Tue 20. Nov 2018, 10:53
do you have initialized the channel already with PassThruOpen before calling the IOCTL? Regarding the Pin, this is the only supported one:
uaes_hhl
Post by uaes_hhl » Fri 30. Nov 2018, 04:51
Hey, thank you for your reply. When I sent the can message, I encountered this problem:“Bus error: an error counter reached the 'heavy'/'warning' limit”. Can you tell me what caused it?
Post by M.Maidhof » Fri 30. Nov 2018, 11:34
possible reasons:
- wrong CAN cable
- no second active CAN node on your network
- no termination resistors in your CAN cables
- wrong baudrate
