supporting both PCAN-USB and PCAN-USB-Pro-FD
I have a linux (kernel v4.18.10) app using a PCAN-USB / PCAN-USB_Pro_FD device. I've just upgrated the PCAN drivers to v8.4.0.
We're using the PCAN Basic (legacy) API. If I plug in a plain PCAN-USB everything works as normal. However, when I plug in a PCAN-USB-Pro-FD device, the application doesn't work. I see that the Pro-FD device now creates a different device file (/dev/pcanusbfd32, instead of the original /dev/pcanusb32 device created for the standard pcan-usb device).
Is there a way to get the Pro-FD device to register as a standard 2-port pcan-usb, so we get the old behaviour back? We don't use any of the FD features and I don't want to update to the new API (yet).
Thanks.
BC
PS. Compiling on kernel 4.18.10 was a pain but it did work by disabling all the other device types except usb.
Thanks.
BC
Re: supporting both PCAN-USB and PCAN-USB-Pro-FD
as a first step, please always use the latest available driver, when using such a new kernel. At the moment we have released peak-linux-driver-8.7 (see our support-Linux website for more details).
Please also use the latest PCANBasic API which you can download from our support website.
When using PCANBasic API, you don´t have to care for the device name. You just call:
Status = CAN_Initialize(PCAN_USBBUS1, PCAN_BAUD_500K, 0, 0, 0);
for the first PCAN-USB channel.
Please also have a look into the driver manual, to see how the device names are defined.
OK, I've updated to the latest v8.7.0. This builds all modules fine on my kernel.
Next up, I'm trying to get the 32-bit libraries to build on my 64-bit machine. My gcc supports 32-bit compilation and I have glibc-devel.i686 installed (this is a redhat / Fedora27 machine). What else do I need?
Thanks.
Thanks.
To answer my second question: the Makefile in the PCAN-USB driver library subfolder has errors:
- line 78 should read "ifeq ($(RT),NO_RT)"
- the define block below needed the "-e" option added to the echo command. Note, this is apparently non-portable but without it the newlines in the define block are not handled correctly.
Now I've got 32-bit libs, I can get back to debugging my original problem.define LIBC32_NOK
$(shell echo -e "
#include <sys/cdefs.h>\n
int main() { return 0; }" | $(CC) $(GCC_32OPT) -o /dev/null -x c - 2>&1)
endef
- S.Grosjean
- Software Development
Many thanks for your feedback, you're right: line 78 is wrong and will be fixed accordingly.
Regarding the "-e' option: yep, it is actually not portable. Can you tell us what is your Linux system please? We'll include a fix to this too.
Thank you for your help in improving the pcan driver,
— Stéphane
- S.Grosjean
Hi again,
Can you please change "lib/Makefile" by replacing your "echo -e" with "/bin/echo -e", to prevent your make utility from running the "echo" command version of its own $SHELL?
Thank you,
Thank you,
— Stéphane
OK, thanks for the feedback. The change to "/bin/echo -e" works here.
My system (distribution) is Fedora27. uname -a output: Linux pulsef27dev 4.18.19-100.fc27.x86_64 #1 SMP Wed Nov 14 22:04:34 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Now I'm back to testing my application, the problem I have is that the PCAN-USB-ProFD devices doesn't seem to work at all (tested on two devices so I don't think its a hardware failure). However, the basic PCAN-USB device (single port) works fine.
When I try to test the Pro-FD device using either the pcanfdtst or receivetest/transmitest example programs, these programs hang. The process become "unkillable" (even using kill -9 <PID> doesn't exit it). I guess this means the application is stuck in a sys-call can can't be interrupted. v. v. bad
I was hoping that if I changed my app to use the newer pcanfd API it would work but if the pcanfdtst program doesn't work, then its a more serious problem. I've got no idea what to try next. Please advise!
BC
BC
- S.Grosjean
When the application hangs on the USB-Pro FD, can you please open a new terminal window, then type:
$ dmesg
— Stéphane
- S.Grosjean
Ok I think we get it!
Can you please try this:
--- a/driver/src/pcan_fops_linux.c
+++ b/driver/src/pcan_fops_linux.c
@@ -1130,7 +1130,8 @@ static long pcan_compat_ioctl(struct file *filep, unsigned int cmd,
break;
default:
- err = __pcan_ioctl(filep, cmd, argp);
+ pcan_put_dev_unlock(dev, 0);
+ return __pcan_ioctl(filep, cmd, argp);
return pcan_put_dev_unlock(dev, err);
— Stéphane
Yes, your patch works! All good now.
What's the likely time-scale for a new release incorporating this fix? While I can continue with the patch in the immediate term, I'd like to use a formal release for our own release-build.
Thanks.
Thanks.
