Signal type conversion
Programmable Sensor Module with CAN Connection
moataza151
Post by moataza151 » Wed 2. Jan 2019, 17:09
I have a PCAN-GPS and I am creating a database file to read the physical CAN signals. I have an issue with the signal type, the device manual says the GPS_Longitude _Degree is a Floating-point number however the signal length is 16 bit (length of an integer) is there any way to work around this issue.
Thank you!
Muataz
S.Michaelsen
Hardware Development
Re: Signal type conversion
Post by S.Michaelsen » Thu 3. Jan 2019, 09:57
the table in the manual is a little bit unclear at this point. Only the GPS_Longitude_Minutes signal is a float value while GPS_Longitude_Degree is a 16 bit unsigned int.
You can find a signal description in our symbol file format in the PCAN-GPS-Package that you can download on the product web page (Examples/PCAN-Explorer/PCAN-GPS_example.sym). You can view / edit / export symbols using the PCAN-Symbol Editor. Might avoid you some work...
BR,
Stephan
