How to disabled TesterPresent
H.Tina
Post by H.Tina » Thu 10. Jan 2019, 10:45
Dear sir or Mrs
I have a question want to ask for help ,after send SvcDiagnosticSessionControl(10 03) services,then TesterPresent Sevices will be send Automatic in period. I have see someone ask for this question and solve it .so I did as the example by the step .but Why I did not worked
my code as follwing,can you help me changed it
TPUDSStatus status;
            status = UDSApi.SvcDiagnosticSessionControl(m_PcanHandle, ref UDSMsg, UDSApi.TPUDSSvcParamDSC.PUDS_SVC_PARAM_DSC_ECUEDS);
            if (status == TPUDSStatus.PUDS_ERROR_OK)
                status = UDSApi.WaitForService(m_PcanHandle, out ResponseMsg, ref UDSMsg, out UDSMsg);
                   TPUDSSessionInfo sessionInfo = new TPUDSSessionInfo();
                   int sessionSize;
                   IntPtr sessionPtr;
                   sessionInfo.NETADDRINFO.SA = 0xF1;
                   sessionInfo.NETADDRINFO.TA = (byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_ECU_1;
                   sessionInfo.NETADDRINFO.TA_TYPE = TPUDSAddressingType.PUDS_ADDRESSING_PHYSICAL;
                   sessionInfo.NETADDRINFO.RA = 0x00;
                   sessionInfo.NETADDRINFO.PROTOCOL = TPUDSProtocol.PUDS_PROTOCOL_ISO_15765_2_11B;
                   sessionSize = Marshal.SizeOf(sessionInfo);
                   sessionPtr = Marshal.AllocHGlobal(sessionSize);
                   Marshal.StructureToPtr(sessionInfo, sessionPtr, false);
                   status = UDSApi.GetValue(m_PcanHandle, TPUDSParameter.PUDS_PARAM_SESSION_INFO, sessionPtr, (uint)sessionSize);
                   sessionInfo = (TPUDSSessionInfo)Marshal.PtrToStructure(sessionPtr, typeof(TPUDSSessionInfo));
                   Marshal.FreeHGlobal(sessionPtr);
                   sessionInfo.SESSION_TYPE = (byte)UDSApi.TPUDSSvcParamDSC.PUDS_SVC_PARAM_DSC_DS;
                   status = UDSApi.SetValue(m_PcanHandle, TPUDSParameter.PUDS_PARAM_SESSION_INFO, sessionPtr, (uint)sessionSize);
I hope can solve this problem,this confusing me a long time
best wishes
H.Tina
Re: How to disabled TesterPresent
Post by H.Tina » Thu 10. Jan 2019, 12:47
Dear
Can someone help me .I did like you said in form ,but the result is like this
2F 44 00 44 00 44 00 44
4326) 241919.0 Rx 0706 8 20 00 44 00 44 00 44 00
4327) 241929.3 Rx 0706 8 21 44 00 44 00 44 00 44
4328) 241939.3 Rx 0706 8 22 00 44 00 44 00 55 55
4329) 241939.6 Rx 0706 8 02 3E 80 55 55 55 55 55
4330) 241942.3 Rx 0716 8 03 7F 36 78 00 00 00 00
4331) 241952.3 Rx 0716 8 03 7F 76 11 00 00 00 00
4332) 243802.5 Rx 0706 8 02 3E 80 55 55 55 55 55
3E 30 is still active.How to solve it .Thank you very much
best wishes
Post by K.Wagner » Thu 10. Jan 2019, 15:32
Dear,
within the UDS package you will find two sample projects in C++, "PCUClient" and "PCUServer". The PCUClient has in its _tmain function several test-function calls. One of them is "testDiagnosticSessionControl". You can comment out the others and check the behavior of it by starting the server on a PCAN channel and the cleint ina second channel.
Main function of PCUClient.cpp
when this function runs, it will first configure a programming session, so that it will start sending the TesterPresent message.
Transmitting TesterPresent
After hitting a key it will disable again by configuring the session as DEFAULT. You will see, TesterPresent messages are not transmitted anymore.
TesterPresent is disabled again
Please check and understand the code and then port it to your programming language as needed (C#)
H.Tina
Post by H.Tina » Fri 11. Jan 2019, 07:40
Dear Sir
I have see the example servel times and did as the example,but TesterPresent still active. the following is my code ,can you take a time to see,and check it ,if is wrong please help me corrected it .Then i will be deeply greetful.Thank you very very very much
TPUDSNetAddrInfo N_AI = new TPUDSNetAddrInfo();
N_AI.SA =(byte)TPUDSAddress.PUDS_ISO_15765_4_ADDR_TEST_EQUIPMENT ;
N_AI.TA =(byte)TPUDSAddress .PUDS_ISO_15765_4_ADDR_OBD_FUNCTIONAL;
N_AI.TA_TYPE = TPUDSAddressingType.PUDS_ADDRESSING_FUNCTIONAL;
N_AI.RA = 0x00;
N_AI.PROTOCOL = TPUDSProtocol.PUDS_PROTOCOL_ISO_15765_2_11B;
TPUDSMsg UDSMsg = new TPUDSMsg();
TPUDSMsg ResponseMsg = new TPUDSMsg();
UDSMsg.NETADDRINFO = N_AI;
TPUDSStatus status;
status = UDSApi.SvcDiagnosticSessionControl(ch,refUDSMsg,UDSApi.TPUDSSvcParamDSC.PUDS_SVC_PARAM_DSC_ECUEDS);//10 03
        int sessionSize;
        IntPtr sessionPtr;
        status = UDSApi.GetValue(ch, TPUDSParameter.PUDS_PARAM_SESSION_INFO, sessionPtr, (uint)sessionSize);
        status = UDSApi.SetValue(ch, TPUDSParameter.PUDS_PARAM_SESSION_INFO, sessionPtr ,(uint)sessionSize);
best wishes
H.Tina
Post by H.Tina » Fri 11. Jan 2019, 08:56
Dear
I have solved this question .Thank you very mush
best wishes
omg991
Post by omg991 » Tue 15. Sep 2020, 16:48
i've the same problem that the "tester present" doesn't stopping, how did you solve?
Post by K.Wagner » Wed 16. Sep 2020, 15:22
please see this post: viewtopic.php?f=182&t=6031
