Hello everybody,
I work in a compagny which made electric vehicle prototypes and we use pcanexplorer 5 for CAN data access...
Today, the "plotter" is a wonderful tooI to carried out CAN data logging but I have some problem to adjust an appropriate data logging rate. Maybe someone could help me.
At the moment, I can log data in the millisecond range but this create too important data in my ".csv" file, especially when I have to make recording during several hours!
I would like to increase the update interval of the plotter to at least 1 seconde or more, but it seems that it's not "directly" possible. My local peak system supplier told me that first I need to create a virtual variable which will have the refresh rate that I want. Then, I need to create a macro which will be used in the plotter in order to log the data that want with the rate that I desire. Is that right?
Does anyone have already made this kind of operation? I don't know the virtual basic language and I don't really know how I can link the virtual var to the marcro and then the macro to the plotter...
Thank you very much for your help
Plotter-Addin: How to reduce datapoints in a Plot?
Re: Plotter logging rate
yes, you can handle that with the help of a virtual variable and a simple VBmacro.
So here is an example symbol file with a virtual variable:
and here is a VBmacro, to update the VirtualVar1 only every second:
Please apply the symbol file and the Macro then start the ReduceLoggingRate Macro in the Macro List. Then use the VirtualVar1 in your Plotter, instead of your normal signal/variable.
Take care to uncheck the Auto Update Intervall in the Plotter properties (Plotter->General-> Auto Update), to have only one plot point each second.
FormatVersion=5.0 // Do not edit!
Title="franz"
{SENDRECEIVE}
[mySymbol]
ID=111h
DLC=8
Var=myVariable unsigned 0,8
{VIRTUALVARS}
Var=VirtualVar1 unsigned
'FILE DESCRIPTION: Macro to reduce Data in plot file
Sub ReduceLoggingRate()
Dim var, virt_var
Set var = Signals("myVariable")
Set virtvar = Signals("VirtualVar1")
While True
virtvar.Value = var.Value
Wait(1000) ' Update each 1000ms, so that you have a Plotter point only every second.
Wend
End Sub
Thank you for your answer! However, I still have questions
I can understand that this virtual variable will be logg each seconde but it don't represent anything...
I had 3 signals to logg (voltage, SOC and current which is in a different CAN message than the two others). I suppose that I need to link these CAN messages to one or maybe three virtual variables? Right?
How can I do that?
Thank you
How can I do that?
Thank you
Yes, you are right. You need than 3 virtual Variables that "pick" every second the Value of your real CAN Signal.
