The Header pinout information
henry
Post by henry » Mon 22. Jul 2019, 04:59
I want to use the four channel PCAN-PCI Express FD Card. BUT I don't want to use the DP9 connector, What is the Pin out information of the 10 pin header? is the same Pinout as DB9 connector(Pin2 CANL, Pin7 CanH)? it's not listed in your spec.
Thanks!!
H.Adamiak
Design & Documentation
Re: The Header pinout information
Post by H.Adamiak » Mon 22. Jul 2019, 09:11
The pin assignment is:
Pin 1: 5V or CAN-Low if you use daisy chain
Pin 2: GND
Pin 3: CAN-Low
Pin 4: CAN-High
Pin 5: GND
Pin 6: Not connected or CAN-High if you use daisy chain
Pin 7 to 10: Not connected
We will add this to the documentation. In the manual of the PCAN-PCI Express (without FD) it is already shown but this card does not have the daisy chain option. So it differs a little.
