PCI CAN bus with IXXAT CAN BUS Replacement
Posted: Sun 18. Aug 2019, 11:50
by arifahmadpk
i am first time using the PCAN. Can we replace the IXXAT PCI CAN bus Card with Peak PCI CAN bus Card? we have one SCADA/HMI System which developed by cigarette machine manufacturer (HAUNI) and they used IXXAT PCI CAN Bus card into PC. we have not source code file of that SCADA/HMI Program. but we have runtime exe file. So we want to make another copy of that system and used the Peak PCI CAN bus Card except of IXXAT PCI CAN bus Card. Waiting for your prompt response.
Arif Ahmad
Re: PCI CAN bus with IXXAT CAN BUS Replacement
Posted: Mon 19. Aug 2019, 09:37
do you work under Linux or Windows? If you work under Linux, do you use the SocketCAN interface?
Posted: Mon 19. Aug 2019, 09:56
by arifahmadpk
Thanks for your reply, But we use Windows 2000.
Best Regard
Arif Ahmad
Posted: Mon 19. Aug 2019, 10:33
to change the CAN interface of a Windows application, you have to change the CAN library in the application. This will only be possible if you have access to the source code of the application.
Posted: Mon 19. Aug 2019, 10:55
by arifahmadpk
Ok, Thanks for your information. We have not source code of that project. that means we must used the IXXAT CAN-bus Card.
Best Regards,
Arif Ahmad
Posted: Mon 19. Aug 2019, 11:37
Try to contact the manufacturer of the software tool for help.
