For beginners, how to route one ID to another ID
Universal CAN Converter
liviu2004
Post by liviu2004 » Fri 23. Aug 2019, 20:43
Hi, please bear with me, I need a kick to get the wheel rolling. Yes, beginner in all this.
Problem: I bought a corner lighting module, which looks to the HSCAN of a car, and turns on and off individually each fog light, based on input data engine running and steering angle sensor data. Nice, however, it turned out that the message ID for steering angle data mismatches my car. Maker does not want to support, no reply, nothing.
So I went ahead, reversed engineer my SAS sensor and got the ID and data bytes necessary (thank you PCAN-USB pro for making this easy to me :)). I went to a supported car, reversed engineer the SAS there and got the ID.
It turns out, I only need to change the ID, from 180h to 1E4h, the rest of the message looks the same. I have a PCAN-Router I would like to use. Attached is the schematic of what I want to achieve. Yes, I know I have to have a module which acknowledges the ID messages, but that is a problem for later to think off.
Easy job to setup PCAN-Router, is it? :oops:
Manual reading, all resources of PCAN-router can be accessed by the .a library, which is explained by .h header files.
I will comply and read them by the letter.
However, how do I follow the right steps? I created a folder Steering angle sensor, copied there folders:
.dep
.lst
.obj
.out
Copied all .h files, Flash.Id, hex2bin.exe and makefile.
Is this for a start ok? Are there any folders / files I don't actually need there? What about crt0.S? What is this file used for? Do I always need it?
In terms of writing .c files, is there a specific order, specific file names, how would one start from scratch? I see in the ROUTING example a can_user.c and main.c. Why there are two files? What do I need to put in each?
Sorry for the long text, I have more questions then I can turn my head around at this time. Can anyone give me a kick in the right road?
liviu2004
Re: For beginners, how to route one ID to another ID
Post by liviu2004 » Fri 23. Aug 2019, 22:11
I'm so far making a main.c file.
I still have to sort out if this is correct and how I set 500 kb/s. And what about the can_user.c
#include "datatypes.h"
#include "can.h"
#include "can_user.h"
#include "hardware.h"
#include "crc_data.h"
// identifier is needed by PCANFlash.exe -> do not delete
const b8_t Ident[] __attribute__ ((used)) = { "PCAN-Router"};
// info data for PCANFlash.exe
const crc_array_t  C2F_Array __attribute__((section(".C2F_Info"), used)) = {
	.Str = CRC_IDENT_STRING,
	.Version = 0x21,
	.Day = 5,
	.Month = 5,
	.Year = 6,
	.Mode = 1,
	// crc infos are patched during link time by flash.ld
	// crc value is patched by PCANFlash.exe
// variables for LED toggle
static u8_t LED_toggleCAN1;
static u8_t LED_toggleCAN2;
// main()
// entry point from crt0.S
int  main (void)
	// init hardware
	HW_Init();
	// init CAN
	CAN_UserInit();
	// Set green LEDs for CAN1 and CAN2
	HW_SetLED ( HW_LED_CAN1, HW_LED_GREEN);
	HW_SetLED ( HW_LED_CAN2, HW_LED_GREEN);
		// main loop
	while (1)
		CANMsg_t  RxMsg, TxMsg;
		// process messages from CAN1
		if ( CAN_UserRead ( CAN_BUS1, &RxMsg) != 0)
			// message received from CAN1
			LED_toggleCAN1 ^= 1;
			if ( LED_toggleCAN1)
				HW_SetLED ( HW_LED_CAN1, HW_LED_ORANGE);
			else
				HW_SetLED (HW_LED_CAN1, HW_LED_GREEN);
			// catch ID 180h from CAN1 to modify the ID to 1E4h
			if ( RxMsg.Id == 0x180  &&  RxMsg.Type == CAN_MSG_STANDARD)
				RxMsg.Id = 0x1E4;
				RxMsg.Type = CAN_MSG_STANDARD;
			// copy message
			TxMsg.Id   = RxMsg.Id;
			TxMsg.Type = RxMsg.Type;
			TxMsg.Len  = RxMsg.Len;
			// send
			CAN_UserWrite ( CAN_BUS2, &TxMsg);
Reason: Changed [quote] to [code]
liviu2004
Post by liviu2004 » Sat 24. Aug 2019, 08:41
Overnight thinking, I guess my chosen code not only changes the ID of the message, but will route also all other messages from can1 to can2, which I don't want. In order to solve my acknowledgment problem, I want now to connect both can1 and can2 to the same car CAN network, so taking messages on can1 and push them back on can2 would not be very smart of me. I've checked and ID 1E4h does not exist in my car, so no ID conflict possibilities there, which kind of make sense, otherwise I would of not need an PCAN-Router.
liviu2004
Post by liviu2004 » Sat 24. Aug 2019, 09:53
I hope this would be good, not sure how if syntax exactly works, I thought only one instruction if 1 but I might be wrong.
// catch ID 180h from CAN1 to modify the ID to 1E5h
	RxMsg.Id = 0x1E5;
	// copy message
	// send
Reason: Inserted [code] tag for improved readability
Post by M.Maidhof » Mon 26. Aug 2019, 11:39
all information on how to build own software for the PCAN-Router module can be found in the manual of the PCAN-Router and it looks like you were able to build your own code.
In your code you copy the RxMsg data to a TxMsg structure, but ID and type are still set to RxMsg...makes no sense IMHO, when you send TxMsg later on CAN2 :?
RxMsg.Id = 0x1E5;
// copy message
// send
liviu2004
Post by liviu2004 » Tue 27. Aug 2019, 20:48
Thanks for your reply and push forward. However, I adapted the code taken from downloads examples:
// catch ID 120h from CAN1 to modify the ID and message type
			if ( RxMsg.Id == 0x120  &&  RxMsg.Type == CAN_MSG_STANDARD)
				RxMsg.Id = 0x4ED8;
				RxMsg.Type = CAN_MSG_EXTENDED;
// copy message
			TxMsg.Data32[0]	= RxMsg.Data32[0];
			TxMsg.Data32[1]	= RxMsg.Data32[1];
			// send
Are the pcan examples wrong then, because I can't get my head around what have I done different? :oops:
Post by M.Maidhof » Wed 28. Aug 2019, 09:17
the example is correct:
// copy message
// send
But your code makes no sense! You modify the RxMsg structure, but later you send the TxMsg structure!
liviu2004
Post by liviu2004 » Wed 28. Aug 2019, 12:03
Thanks again, I am slow but I think I got it. Code prepared all for sending except there was nothing in the data part of the message. I believe it is now time for me to put things at work and see how it works.
liviu2004
Post by liviu2004 » Wed 28. Aug 2019, 21:22
After some puzzling, more reverse engineering and change in the functional specification of my wishes, I'm happy to announce that PCAN-Router has been successfully loaded with correct firmware, and user expectations are met and exceeded. ;)
There are still declarations and data formats a bit unclear to me, but it is up to me to put the brain to work.
Thanks Peak for making this product available.
#include "can.h"
	.Version = 0x21,
	.Day = 5,
	.Month = 5,
	.Year = 6,
	.Mode = 1,
// main()
int  main (void)
	// init hardware
	HW_Init();
	// init CAN
	CAN_UserInit();
		// main loop
	while (1)
			//message received from CAN1;
			else
			// catch ID 180h from CAN1 to process various changes
				//change data byte 00 to 03, 01 to 02, 04 to 01, 01 to 04 and add 2 fixed values
				RxMsg.Data8[3] = RxMsg.Data8[0];
				RxMsg.Data8[2] = RxMsg.Data8[1];
				RxMsg.Data8[0] = 0x84;
				RxMsg.Data8[1] = RxMsg.Data8[4];
				RxMsg.Data8[4] = RxMsg.Data8[1];
				RxMsg.Data8[5] = 0x00;
				// copy message and set data length to 6 bytes
				TxMsg.Len = 6;
				// send
				// message sent to CAN2
				LED_toggleCAN2 ^= 1;
				if ( LED_toggleCAN2)
					HW_SetLED ( HW_LED_CAN2, HW_LED_ORANGE);
				else
