Importing and sending messages from CSV
Hi, I have some recorded messages stored in a CSV file. I would like to use VBScript to import, parse, and send these messages. I'm basically looking for a method to import a line of text from a text file using VBScript in the Explorer-5 environment. The rest I can do. Thanks.
Re: Importing and sending messages from CSV
Opening Files, read lines etc. is raw VBS and have nothing to do with the PE5 Extensions.
Here is a simple Maro that load a Text File Line by Line and write the Data of each line to the transmit List. (PE4 Macro - but easy to port to PE5)
' Dieser Makro laedt CAN-Botschaften aus einer Textdatei in die Sendeliste,
' wobei in der Textdatei die Botschaften in folgender Form gespeichert sind:
' CAN-ID(Hex,3 Zeichen) DLC Daten(Hex), Z.B. 100 5 1A 5F C4 3B FF
Sub LadeNachrichten()
Const ForReading = 1
Dim fso
Set fso = CreateObject("Scripting.FileSystemObject")
Dim FileName
FileName = "C:\Temp\Test.log"
' Abfrage des Dateinamens
FileName = InputBox("Dateiname:",, FileName)
If Not fso.FileExists(FileName) Then
MsgBox "Datei existiert nicht!"
Exit Sub
End If
' Datei oeffnen
Dim tf
Set tf = fso.OpenTextFile(FileName, ForReading)
' Alle Zeilen der Datei lesen
Dim Line, Msg, n
While Not tf.AtEndOfStream
Set Msg = TransmitMessages.Add
Msg.ID = CInt("&H" & tf.Read(3)) ' 3 Zeichen CAN-ID in Hex
tf.Skip(1)
Msg.DLC = CInt(tf.Read(1)) ' 1 Zeichen DLC
tf.Skip(1)
For n = 0 To Msg.DLC-1
Msg.Data(n) = CInt("&H" & tf.Read(2)) ' Jeweils 2 Zeichen Hex-Daten
tf.Skip(1)
Next
tf.ReadLine ' Gehe zur nõchsten Zeile
Wend
tf.Close ' Datei schliessen
End Sub
