C# Example
A free API for the Communication with Control Units based on the CAN Calibration Protocol (CCP) by ASAM for Windows®
diantn
C# Example
Post by diantn » Tue 2. Oct 2012, 14:22
I'm trying to run the C# example using Microsoft Visual C# Express.
But it says that the PCCP.dll can't be found although I tried numerous way to include it, such as:
- put into project dir
- put into bin\Debug dir
- put into System32 dir
- set as PATH
Could you please help?
diantn
Re: C# Example
Post by diantn » Tue 2. Oct 2012, 14:33
Hi again,
Sorry for my previous post. :-)
I solved it by putting PCANBasic.dll in the same location as the PCCP.dll, which was not the case.
I got confused because the system says it can't find PCCP.dll and not the PCANBasic.dll.
Re: C# Example
Post by K.Wagner » Tue 2. Oct 2012, 14:39
Hello diantn,
Please check that the both dlls (PCCP.dll AND PCANBasic.dll) are located eather in the Windows\System32 folder or in the folder where the exe using the API is located, so that you have three files like in the following picture:
Files needed
Files needed
