Digital input various results
marek.belisko
Post by marek.belisko » Wed 27. Nov 2019, 12:14
I'm using MicroMod Mix3 to capture state of digital inputs. I use DIN0 - DIN2 as inputs and while set on all of then reference 4.8V when capture received data by using candump I see n that I get logical 1 but after some seconds it goes to logical 0 and then back to logical 1. as said I have stable input voltage 4.8V. Any ideas what can cause this issue? I have basic setup only (no changes in DIP switches though). Thanks.
Re: Digital input various results
Post by M.Heidemann » Wed 27. Nov 2019, 13:37
Can you send us your configuration-file (.mcf) to support[at]peak-system.com?
Please reference this post in your email.
It's hard to evaluate whats the issue without seeing the configuration.
marek.belisko
Post by marek.belisko » Tue 3. Dec 2019, 08:56
it looks like I need to provide input voltage higher then 4,7-4,8V otherwise detection is not reliable. Not I provide bit more and it works perfectly fine. Thanks.
BR,
marek
Post by PEAK-Support » Thu 2. Jan 2020, 21:51
4.8V is the minimum Voltage for detecting the High Level. it is always better to add some milivolts on top for exact detecting the High Level.
