Sending and receiving messages does not work on Ubuntu 18.04
peak_can_user
Post by peak_can_user » Thu 28. Nov 2019, 12:18
My Cancard-PCI Exrpess FD does not send or receive messages on any of the 4 CANs on Ubuntu 18.04.3 LTS
I installed the driver version 8.9.3 like this:
sudo rmmod pcan
make clean
make NET=NETDEV_SUPPORT
sudo make install
sudo modprobe pcan
if I setup the any of the interfaces with:
ip link set can1 type can bitrate 500000
ip link set can1 up
A message sent with:
cansend can1 123#
apears in
candump can1
     can1  123   [0]
but does not show up on the physical bus.
This is what I get form /proc/pcan
*------------- Release_20191029_n (8.9.3) Nov 27 2019 13:39:45 --------------
*--------------------- 5 interfaces @ major 240 found -----------------------
 0  pcifd   can1 82441000 016 0x001c 00000000 00000002 00000001 00000000 0x0000
 1  pcifd   can2 82442000 016 0x001c 00000000 00000006 00000001 00000000 0x0000
 2  pcifd   can3 82443000 016 0x001c 00000000 00000002 00000001 00000000 0x0000
 3  pcifd   can4 82444000 016 0x001c 00000000 00000002 00000001 00000000 0x0000
When sending messages via the USB interface everything works.
Is there something that I do worng with the PCI-Exress card?
Thanks for your help
S.Grosjean
Re: Sending and receiving messages does not work on Ubuntu 1
Post by S.Grosjean » Thu 28. Nov 2019, 13:39
Could you connect another CAN channel (for example "can2") to the same bus than "can1", configure it like "can1", then do "candump can2" please?
Other suggestion: could your rebuild pcan but not in netdev mode, that is:
$ cd peak-linux-driver-8.9.3
$ sudo make uninstall
$ make clean
$ make
$ sudo make install
Then write the same frame to the bus but with:
$ pcanfdtst tx -b 500k -i 0x123 -l 0 -n 1 /dev/pcanpcifd0
If the 2nd channel is always connected to the same bus, from another window, you can check if the above frame has been written with:
$ pcanfdtst rx -b 500k -n 1 /dev/pcanpcifd1
— Stéphane
