Termination of IPEH-002021
USB to CAN Interface
baryil
Post by baryil » Fri 31. Jan 2020, 09:04
Is the internal termination (serial number >200.00) to be made by soldering simple jumper or 120Ohm surface mount resitor? Thanks.
Re: Termination of IPEH-002021
Post by M.Heidemann » Fri 31. Jan 2020, 09:21
We do not recommend using the internal termination for the PCAN-USB (IPEH-002021).
The likelyhood of running into an over-termination is pretty high in this configuration.
Also the warranty does not cover damages caused during the modification for internal termination.
In case you want to get more information about the internal termination, please send us an email: support[at]peak-system.com
