loopback
novak
loopback
Post by novak » Sat 22. Feb 2020, 18:44
Hello all,
now I'm using PCAN USB PRO FD.
I'm not familiar with pcan view /plin view. Could you please provide me help how to make some kind of connection between LIN1-LIN2 and/OR CAN1-CAN2 with pcan-view and plin-view? I have tried a lot of master/slave/send/receive possibilities without success.
The CAN1/LIN1 is connected to CAN2/LIN2 with straight ribbon cable (pin1 connected to pin1, and so on)
thanks in advice
Jindrich
novak
Re: loopback
Post by novak » Sun 23. Feb 2020, 19:27
RTFM !!! :o)
... For the lin operation an additional supply voltage must be applied to the Vbat-lin (8-18V). Both LIN connections need their own supply.
Re: loopback
Post by M.Maidhof » Mon 24. Feb 2020, 11:01
yes, this is correct for LIN connections between both ports. For CAN you only need a terminated CAN cable with 120 Ohms on both ends between CAN-L and CAN-H
